I have a AMD FX8350 CPU and every now and then I get a voltage warning. i've looked into it a little and apparently I need to set the voltages from auto to a specific voltage. does anyone know what I need to enter into my bios. I have an ASUS M5A99X EVO R2.0 Motherboard....
https://linustechtips.com/topic/69626-voltage-requirements-for-my-cpu/
Are you using....ASUS's AI suite?
If so....I dunno, seems to be a bug with it. I get that as well with my Crosshair V Formula (not no issues when I had my Crosshair IV Formula...)
Use CPU-Z, HWMonitor, or AIDA64 instead (because they do lots more than monitor CPU temperature and voltage).
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
If you are using AI Suite 2, I would uninstall it using this: http://rog.asus.com/forum/showthread.php?28319-AI-Suite-II-uninstall-cleaner and install AI Suite 3:https://linustechtips.com/main/topic/38277-how-to-ai-suite-iii-on-z77-boards/
I would check the voltage with CPU-Z.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
