Hello... I have this pc configuration : mb - G1.Sniper A88X (rev. 3.0) / ram - kingston hyperx genesis 2 x 4 gb, DDR 3, 1600 Mhz, cl9 , 1,5v / ssd - kingston v300 120gb, sata3 / power supply - raidmax - 500w / hdd 1 Tb wd / cpu - AMD A8-6600K 3.9GHz box and i need a vga card. Witch one is the best for my pc? I agree to change some parts if is necesary, but keep in mind that i live in romania and not all the components are available here, or if they are available, probably are very expensiv. Thnx.
https://linustechtips.com/topic/694829-need-help-pls/
5 minutes ago, Denys said:
Do you mean Sapphire Radeon RX 460 Nitro OC 4GB DDR5 128-bit Lite ?
There's a bazillion different RX 460s, but they all share the same graphics processor, so there is not much difference from one 460 to another. So buy whichever one looks the nicest or fits inside of your case or whatever.
i7 4790K || R9 290X + R9 290 || 16GB G.Skill TridentX 1866 || Gigabyte Z97MX Gaming 5 || Crucial MX100 256GB || WD Caviar Blue 1TB
https://linustechtips.com/topic/694829-need-help-pls/#findComment-8903694
Just now, Denys said:
Ok... But if i buy two of them is it worth?
No, better buy a single better one, like a 470 or 480.
https://linustechtips.com/topic/694829-need-help-pls/#findComment-8903716
For your setup that is a good choice. I have always liked sapphire for AMD and like you said if it's available, then for 1080p gaming you should be golden.
I would rather agree on what we share, than fight on what we don't. - Myself
FULL PC SPECS ON PROFILE https://linustechtips.com/main/profile/454099-thinkfreely/
https://linustechtips.com/topic/694829-need-help-pls/#findComment-8903717
