Does anyone have any recommendations for very low cost (as in under $50) upgrades that make PC gaming better? Can be hardware, or things to improve your entire desktop experience.
GTX 3080 Ti ROG | Ryzen 5600X | MSI Tomahawk B550 | 32GB 3600MHz | Corsair 850e | HAF X | WD SN850X | Asus MG287Q 1440p 144Hz
https://linustechtips.com/topic/694398-low-cost-upgrades/
Maybe something like a Modmic if you play a lot of online games with friends. You would't know how better it is to talk to someone with a decent mic.
ZamoRIG 2.0:
Processor: AMD Ryzen 7 1700 @ 3.9GHz
Cooling: DeepCool Captain 240 RGB + 2x Corsair ML120 fans
Graphics Card: Gigabyte GTX 1070 G1 Gaming x2
Motherboard: Asrock X370 Gaming K4
RAM: 2x8GB DDR4 G Skill Ripjaws V Grey @ 2800MHz
SSDs: 2xPatriot Ignite M.2 240GB
HDD: WD Black 1TB + WD Green 2TB
 PSU: Corsair RM750
Case: Corsair Carbide 400C
ZamoRIG “Portable”:
Processor: AMD Ryzen 5 1600 @ 4GHz
Cooling: Corsair H80i
Motherboard: Gigabyte AB350N Gaming WiFi
RAM: 1x16GB DDR4 Corsair Vengance  @ 2400MHz
SSD: Patriot Ignite M.2 240GB
HDD: 2TB 2.5” Seagate HDD
PSU: Corsair TX650M
Case: Siverstone SG13
https://linustechtips.com/topic/694398-low-cost-upgrades/#findComment-8899618
An SSD or more RAM. depends what you already have.
Black Knight-
Ryzen 5 5600, GIGABYTE B550M DS3H, 16Gb Corsair Vengeance LPX 3000mhz, Asrock RX 6800 XT Phantom Gaming,
Seasonic Focus GM 750, Samsung EVO 860 EVO SSD M.2, Intel 660p Series M.2 2280 1TB PCIe NVMe, Linux Mint 20.2 Cinnamon
Daughter's Rig;
MSI B450 A Pro, Ryzen 5 3600x, 16GB Corsair Vengeance LPX 3000mhz, Silicon Power A55 512GB SSD, Gigabyte RX 5700 Gaming OC, Corsair CX430
https://linustechtips.com/topic/694398-low-cost-upgrades/#findComment-8901348
If it's running off WiFi, you could probably run an Ethernet cable to it from your router for less than $50.
Yes, it's 2871 as in the year 2871. I traveled all this way, back in time, just to help you. And you thought your mama lied when she said you were special-_-
https://linustechtips.com/topic/694398-low-cost-upgrades/#findComment-8901528
I'm currently using home plugs which gets me about 50% of what a straight wired connection would, which is still a good speed. I'm not sure how you would wire an Ethernet cable though - my PC is on the complete opposite side of the house to my router in X, Y and Z directions.
https://linustechtips.com/topic/694398-low-cost-upgrades/#findComment-8902137
you just pull em trough the floors or walls like regular power cables. the max length for a cat 5 cable is 2.5 kilometer i believe so that should be enough lol.
https://linustechtips.com/topic/694398-low-cost-upgrades/#findComment-8903617
You could do as @tlink says. Or, in my case, I run a white cable that matches my outside house paint color, like the DirectTV line, then up the window and into my computer room.
https://linustechtips.com/topic/694398-low-cost-upgrades/#findComment-8904048
