C Programing, While loop not working.
Go to solution Solved by danejesse1,
In your switch you don't have a break statement. Also, scanf("%d", rerun) needs a &rerun since rerun is an int, not a pointer to an int.
Edit: it looks like you're missing a break statement in your first switch, too.
switch(rerun) {
	case 1:
		k=0;
		break; // Missing this break statement
	case 2:
		k=1;
		system("pause");
Hi,
Thanks for helping me out, if you're wondering why I'm not posting on stack overflow, it's because I have a cool down for some reason.
Here's my code:
#include<stdio.h>
#include<stdlib.h>
#include<ctype.h>
#include<string.h>
void BookingSystem()
	int nineNaboo=0;
	int nineTattoine=0;
	int sevenEndor=0;
	int nineEndor=0;
	int sevenNaboo=0;
	int sevenTatooine=0;
	int ninej=0;
	int seventable=0;
	int sevenj=0;
	int ninetable=0;
	int k=0;
	int time=0;
	int rerun;
	while (k==0)
		printf("\nWelcome to the booking System\nMeals are served at 9pm and 7pm, please enter what time you would like to book for.\n\n");
    	scanf("%d", &time);
	if (time==7)
       	printf("\nYou have selected to book your slot at 7PM\n");
        k=7;
	else if (time==9)
		printf("\nYou have selected to book your slot at 9PM\n");
	while (ninej==0)
		printf("Please enter what table you would like to book\nPlease enter: \n\n'1' for Endor \t'2' for 'Naboo'\t'3' for Tattoine");
		scanf("%d", &ninetable);
		switch(ninetable)
				case 1:
						if (nineEndor==1)
							printf("Sorry, this table has already been booked, please selected another table\n");
							ninej==0;
						if (nineEndor==0)
						printf("You have selected to book your table at Endor, your table has been booked for 9PM");
						nineEndor = 1;
						ninej=1;
				case 2:
						if (nineNaboo==1)
							ninej=0;
						if (nineNaboo==0)
						printf("You have selected to book your table at Naboo, your table has been booked for 9PM");
						nineNaboo = 1;
						ninej=1;
						break;
				case 3:
						if (nineTattoine==1)
							ninej=0;
						if (nineTattoine==0)
						printf("You have selected to book your table at Tattoine, your table has now been booked for 9PM");
						nineTattoine = 1;
						ninej=1;
	else
		printf("\nYou have selected an incorrect time, please try again.\n\n");
		k=0;
	printf("\n\nIf you would like to book another table, please say select '1' for Yes, and '2' for No.");
	scanf("%d", rerun);
	switch(rerun)
		case 1:
				k=0;
		case 2:
				k=1;
				system("pause");
int main()
	BookingSystem();
Okay, as you can probably see. I'm trying to get my program to loop back to the beginning whenever K is turned into something other than 0. Any loops I try result in it either not working or a crash. I think I'm missing something really essential from a while loop, and I can't seem to think what it is.
Thanks for helping me out, and sorry if I explained this poorly.
https://linustechtips.com/topic/694351-c-programing-while-loop-not-working/
switch(rerun) {
	case 1:
		k=0;
	case 2:
		k=1;
		system("pause");
Edited by danejesse1
looks like break statement is missing.
Intel Core i3 2100 @ 3.10GHz - Intel Stock Cooler - Zotac Geforce GT 610 2GB Synergy Edition
Intel DH61WW - Corsair® Value Select 4GBx1 DDR3 1600 MHz - Antec BP-300P PSU
WD Green 1TB - Seagate 2.5" HDD 1TB - Seagate Barracuda 500GB - Antec X1 E.
switch(rerun) {
	case 1:
		k=0;
	case 2:
		k=1;
		system("pause");
Thank you!
I was literally searching my code for at least 30 mins trying to figure it out. I can't believe I couldn't see that stupid mistake!!
Thanks a lot, you've saved my sanity xD
