6 minutes ago, Shivan said:
I want to put a m.2 and 3 ssds into my asrock x99e-itx, but i heard m.2 disables some sata ports. WHich ports are those
read the manual
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/694328-help-with-m2/#findComment-8898627
This is only really something to worry about on Z170 boards, X99 has enough lanes (or something like that, can't remember exactly where I found this info, think it was somewhere on LTT) to negate M.2 using them.
Just now, SeanAngelo said:
read the manual
This
“sufficiently advanced technology is indistinguishable from magic still going to require driver rollbacks when it stops working for no reason“
https://linustechtips.com/topic/694328-help-with-m2/#findComment-8898633
https://linustechtips.com/topic/694328-help-with-m2/#findComment-8898695
