Just now, ripper101 said:
So I am wondering exactly which CPU would be the best for playing CPU bound games like Arma 3 or DayZ SA. Would I see more performance in a 6800k or a 6700k or would there be little difference? thanks
isn´t dayz horribly optimized? and arma 3 idk.. but whats your current cpu?
Watches and computers
https://linustechtips.com/topic/694321-what-cpu-best-for-arma/#findComment-8898515
They recently added a new renderer massively improving FPS but the game is still broke
4440
2 minutes ago, UberGamerKing said:
Holy shit
i7's have near no benefit when it comes to gaming.
At most, 98% of people will need a 6600K at MAX
in some cases it matters
https://linustechtips.com/topic/694321-what-cpu-best-for-arma/#findComment-8898542
4440
you dont need a better cpu than 4440. i have the same cpu and i can play arma
https://linustechtips.com/topic/694321-what-cpu-best-for-arma/#findComment-8898553
6700k.
what cpu do you have now?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/694321-what-cpu-best-for-arma/#findComment-8898626
13 hours ago, ripper101 said:
i5 4440
should be fine for arma and such...
Old Rig
https://linustechtips.com/topic/694321-what-cpu-best-for-arma/#findComment-8902275
