Micro* ATX.
ATX:
More expansion slots
More RAM slots (depends on the motherboard)
Bigger
mATX:
Less expansions slots
Less RAM slots (most of the time it's the same amount as ATX though)
Smaller
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/694201-atx-vs-mini-atx/#findComment-8897107
mostly the only difference is less expansion. so less SATA ports, less PCIe slots, less fan/USB connectors, you get the idea.
im using a mATX board right now and i've kinda run out of place to plug things in. im running 4 RAM dimms, a GPU, a PCIe SSD and the thing is kinda packed already!
https://linustechtips.com/topic/694201-atx-vs-mini-atx/#findComment-8897143
Advantages of Full ATX:
- More expandability, e.g. more RAM slots or more PCI-e slots
Advantages of Mini-ATX:
- Allows for a more compact PC which can save physical space
- Cheaper
If you are getting a mid or full tower though, there are no advantages to getting Mini-ATX other than maybe the price difference.
GTX 3080 Ti ROG | Ryzen 5600X | MSI Tomahawk B550 | 32GB 3600MHz | Corsair 850e | HAF X | WD SN850X | Asus MG287Q 1440p 144Hz
https://linustechtips.com/topic/694201-atx-vs-mini-atx/#findComment-8897147
