7 minutes ago, Fabiothrman said:
Mainly for editing no peripherals, OS, or monitor I have them
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($219.99 @ Newegg)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler  ($99.99 @ Corsair)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard  ($74.99 @ Newegg)
Memory: Team Elite Plus 16GB (2 x 8GB) DDR4-2400 Memory  ($64.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($48.89 @ OutletPC)
Case: Fractal Design Core 2300 ATX Mid Tower Case  ($39.99 @ SuperBiiz)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($46.97 @ Newegg)
Total: $595.81
Generated by PCPartPicker 2016-11-20 23:37 EST-0500
https://linustechtips.com/topic/694006-600-build-with-oc/#findComment-8895211
2 minutes ago, Fabiothrman said:
19 minutes ago, Fabiothrman said:
This is a very good build, I just changed a few things here and there and this is what I have.
http://pcpartpicker.com/list/GPbpm8
why would you need overclocking with a video editing build? get an i7/xeon instead.
https://linustechtips.com/topic/694006-600-build-with-oc/#findComment-8895242
Just so you know that build won't play much games.
I know you said editing but then that leads me to think you'll play games record it then edit.
But I guess you could be filming real life stuff and editing that. or just editing pictires.
Everyone should own a vive.
https://linustechtips.com/topic/694006-600-build-with-oc/#findComment-8895245
you still have to pay 650 because rebate is not a discount, its manufacturer giving you money off AFTER your purchase
https://linustechtips.com/topic/694006-600-build-with-oc/#findComment-8895260
14 minutes ago, Fabiothrman said:
I think it's me of rethinking things.
huh?
https://linustechtips.com/topic/694006-600-build-with-oc/#findComment-8895313
Just now, Fabiothrman said:
I was just thinking about the performance that could come from a chip like that and further integration.
you would benefit more from the extra threads than the overclocking.
https://linustechtips.com/topic/694006-600-build-with-oc/#findComment-8895350
1 minute ago, Fabiothrman said:
10 minutes ago, herman mcpootis said:
you would benefit more from the extra threads than the about the xeon but it has ECC which brings down the DDR rating and memory bandwidth
you don't need to use ECC ram, standard ram does fine.
https://linustechtips.com/topic/694006-600-build-with-oc/#findComment-8895385
But doesn't it only support ddr3 memory
the e3 12xx V3 uses ddr3 while the e3 12xx v5 uses ddr4. using ddr3 will not cause any bottlenecks.
https://linustechtips.com/topic/694006-600-build-with-oc/#findComment-8895397
