My pc has been fine until now. I turn it on, the aio cooler lights up then it everything turns off, all in about 3 seconds or so. and it will repeatedly do this, before when this happened It would bring me to the boot screen but it doesnt even get to that
My OS had a corrupted file previously, SSD broke and so had to try and migrate the OS to the HDD. but this seems to only be affecting the search bar
THINGS IVE TRIED:
Reseating battery
reseating RAM
tested cooler, not that either
- SSUPD Meshlicous - Z170I - i7-6700K - Gigabyte 2080 - 16GB Corsair Vengance - 850 EVO 1TB - H115i ICUE Link- SF600
https://linustechtips.com/topic/693995-help-computer-will-not-turn-on/
ok after about an hour or so of this happening its now booting and working??, any idea why? cancel that it just died again as soon as i logged in, now im in the UEFI BIOS
try reseating the battery
Favorite Threads: PSU Tier List
My Stuff n' Things
The Beast (My Rig)   |CPU: AMD Ryzen 7 7800X3D|  |Cooling: Noctus NHU12S Redux, 6x 120mm Noctua Redux|  |Motherboard:  Asus TUF B650-E WiFi|  |RAM: 4x8gb 6000 Corsair VENGEANCE RGB|  |Graphics Card: EVGA(RIP) GeForce RTX 3070TI FTW3|  |Power Supply: EVGA GT 850W|  |Case: Corsair 4000D Airflow Mid Tower Case(Black)|  |SSD: 1Tb SK Hynix Platinum P41 NVMe, 2Tb Inland Prime NVMe, 500gb Inland 2.5", 4tb WD Blue HDD|  |Monitor: MSI Optix MPG341QR 34" Ultrawide|  |Keyboard: Logitech G815|  |Mouse: Logitech G305|  |Audio Interface: FiiO K7 DAC/Amp|  |Headphones: Sennheiser HD6XX |Webcam: Logitech C920, Logitech C270|
My Network Rack  |Switch: Cisco Dell PowerConnect 5548P|  |Router: Unifi USG|  |Rack: 12U|  |Server: HP Z420|  |Services: Proxmox PVE, Wireguard, Pihole, NVR, NAS|
the silver one on the board
My Stuff n' Things
9 minutes ago, Bradders said:
reseating ?
Take it out and put it back in
2 minutes ago, SCHISCHKA said:
does your pump still work? also try talking dirty to it.
pump i think is fine, it was noisy af before for a while but that stopped
would that prevent it from booting?
if you can get to bios check your getting a rpm reading from it. if the pump is dead that would cause your cpu to power off from high temps
ψ ︿_____︿_ψ_
its brought up the american megatrends screen, and under total memory it says 8192MB, I have 16GB in the system
CPU FAN: 786RPM
that could be it. re-seat your memory or try using each one
ψ ︿_____︿_ψ_
right done a RAM test, using one each time then both and in every socket. not that
strange. I suppose you do not have a PSU tester. Try remove your GPU, any hard drives that are not the operating system, and any PCI cards that are not the bare minimum to get it booting.
ψ ︿_____︿_ψ_
im suspecting two things, either cpu cooler ( had problems with it before with it being super noisy making a gargling noise or something) OR the windows OS (have a problem with search bar and indexing, even microsoft hasnt a clue)
if its your cpu cooler check the temp in bios. its shouldnt be super noisy, you might have air bubbles
ψ ︿_____︿_ψ_
temp in CPUz are around 42C MAX
Just now, SCHISCHKA said:
so windows is booting now?
yeah, its booting now and i can login, tried to play WOT again and it crashed later on. this leads me to believe its a CPU cooler problem
its doing its crash thing though. just crashed in the windows menu, only nzxt's cam software running
after it crashes can you get to bios to check the temps?
ψ ︿_____︿_ψ_
sometimes but not often
