Choosing between SSDs
I'm choosing between these SSDs right now:
Price: 70€ - 90€
Size: 240GB - 256GB
Kingston HyperX FURY 240GB 73,60€
SanDisk Z400s 256GB 76,90€
SanDisk Plus 240GB 79,99€
Intel SSD 530 240GB 82,79€
Crucial MX200 250GB 84,63€
Kingston HyperX Savage SSD 240GB 89,95€
(Note: there are more, but the rest are from brands, that I have never heard of)
A lot of my friends use this SSD, but it's expensive:
Samsung 850 EVO 250GB 101,84€
Out of all these, which one is the best in price - performance/endurance/speed?
https://linustechtips.com/topic/693684-choosing-between-ssds/
 The Crucial MX300 275GB and Samsung 750 EVO 250GB are both good options, but in general what you have right there are all very good ones.
The ones I mentioned should be well within your budget.
The way you can compare SSD  performance is by comparing their listed IOPS scores, higher being better. This is the speed of a drive, but generally the endurance is not much different between the drives.
From the top of my head, I know Crucial has rated their 725GB version of the MX300 as being able to handle 200TB of data written to it (before it would die? Or degrade? Either one).
https://linustechtips.com/topic/693684-choosing-between-ssds/#findComment-8892336
MX300 has one [of] the best controllers and NAND package density for the price.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/693684-choosing-between-ssds/#findComment-8892339
4 minutes ago, FTL said:
What about the Crucial BX100? It's 83,53€ for 250GB
7 minutes ago, FTL said:
It is 74,61€ (275GB) here, do you think it is worth or should I pick one from my original post?
I would recommend the MX300, it's a very recent and good SSD with great speeds (530MB/s and 510MB/s for read and write and 78.000 IOPS I think?)
The BX100 is a just a bit older SSD, not much performance difference, but you can get a cheaper SSD with more memory if you go for the MX300.
https://linustechtips.com/topic/693684-choosing-between-ssds/#findComment-8892393
This is the best at the price point.
Please don't. It has a terrible controller.
https://linustechtips.com/topic/693684-choosing-between-ssds/#findComment-8892402
