4 minutes ago, HELP ME PLIS said:
Can you give me a link or something where i could buy seim or full modular PSU's
Here
CPU: I7 5820K@4.0Ghz | Mobo: ASRock X99 Extreme4 | Ram: 4 x 4Gb G.Skill Tridentz@3200Mhz | GPU: XFX 390x | Cooling: Corsair H115i | PSU: Corsair RMX 850x | Storage: Samsung 250Gb 850 EVO + 2tb Seagate HDD | Case: Inwin 805 | Keyboard: Tesoro Gram Spectrum | Mouse: Tesoro Gram H3L | Mousepad: Corsair MM800 RGB  | OS: Windows 10
https://linustechtips.com/topic/692786-help-me-pc-part-picker/#findComment-8883961
This is a pretty decent and not too costly one https://pcpartpicker.com/product/FQ648d/corsair-power-supply-cp9020101na
IM BACK BABY
https://linustechtips.com/topic/692786-help-me-pc-part-picker/#findComment-8883966
8 minutes ago, HELP ME PLIS said:
TNX http://pcpartpicker.com/list/TsqqBP check my build
Get rid of that cooler, there is one included with the CPU. Use the money you saved to get a 1050, 1050ti or maybe even a RX 470 if you can afford it.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/692786-help-me-pc-part-picker/#findComment-8883987
I'd do this (Swapped the 2 4Gb for 1 8Gb gives you a little room for expansion plus dual channel won't make a huge difference you are going for some light gaming)
And do this.
https://linustechtips.com/topic/692786-help-me-pc-part-picker/#findComment-8883994
Also considering getting a B150 board with 4 RAM slots if you can find one for a good price, the extra slots will help you out when you need to upgarde the RAM.
https://linustechtips.com/topic/692786-help-me-pc-part-picker/#findComment-8883998
And do this.
OK i'll get rid of that CPU cooler
i wont upgrade im still in school and i'll stay in it for atleast 4 years
https://linustechtips.com/topic/692786-help-me-pc-part-picker/#findComment-8884005
You could look into a AMD Board/ CPU if you wanted more performance for less $$. Just keep that in mind.
https://linustechtips.com/topic/692786-help-me-pc-part-picker/#findComment-8884036
