Help a peasant ascend! :D
Solved by JFischer00,
5 minutes ago, JustAnotherPeasant said:Sorry, I'm a scrublord x( - 1920x1080 would be godly X)
Alright, well this is just a quick attempt, but here's what I would get. CPUs tend to age well, especially strong CPUs like the 3770. With this combo, you should be able to play any game at 1080p 60 FPS with all settings maxed out easily. You would probably be able to do 1440p too.
