Audio issues after cable management?
Hi yesterday I decided to do some cable management on my system just re- routing cable through different holes built into the case, after which my rig was looking a little better but I'm getting some kinda audio interference that I wasn't before on both my back ports and front panels ports... Any ideas?
My setup
MB: asrock z170 extreme 4
CPU: i7 6700k (water cooled with the h100i aio)
Ram: 16GB EVGA DDR 4
GPU: gtx 1060
https://linustechtips.com/topic/692640-audio-issues-after-cable-management/
Make sure audio cables are not running adjacent to power cables.
I'll try routing the fp audio cable differently, though it was one I didn't move yesterday, the main things i did yesterday was routed my fp button cable through the closes hole to them, instead of the one next to the power supply, and routed my USB header for my water block down through the hole by the power supply, I did also kinda wrap my data data cables around most of the cables for the front panel cause I couldn't find my bag of zip ties, so maybe it's something there?
ok so after completely redoing my cable management ( with no real visual difference) my audio issues have subsided and everything is working perfectly, it seems it was do to my makeshift cable management solution in the back of the case depicted in the above post...
