If it would be 80°C when doing Aida64 stress test with CPU + FPU + cache, I would say you are fine because in real worl usage it would almost never come to that.
But if you get 80°C while playing games ... I wouldn't be comfortable.
It still kinda safe temp and shouldn't do any dammage to your CPU. But what happens when you push CPU to 100%? Jumps to 90°C and above?
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
What voltage should my 6700K be at?
Desktop Rig:
CPU: i7-6700K  Cooler: Noctua NH-L9x65  Graphics card: NVIDIA GeForce RTX 2080 Ti FE  Memory: Corsair VENGEANCE LED 3200Mhz (2x8GB)
Motherboard: ASUS ROG STRIX Z270i  SSD: Samsung 960 EVO 1TB, Samsung PM981 1TB  Case: Louqe Ghost S1
Monitor: Dell Alienware AW3418DW
How long is a piece of string?
It depends on how you did on the silicon lottery. Personally my 6700K will do 4.6 @ 1.35v but requires 1.41v for 4.7 then 1.46v for 4.8.
Main Rig:-
Server:-
at 4,8 GHz it peaks at 1,45 or 1,46. but i haven't tried turning it down in small increments yet, as i overclocked it yesterday before going to bed
Desktop Rig:
I'm not comfortable at 1.46v even with a full custom loop, my temps can hit 90°c when stress testing at that voltage. I tend to stick to 4.6Ghz for everyday use with a 4.7Ghz OC profile saved in my uefi.
Main Rig:-
Server:-
2 minutes ago, kofgokhan said:
Should I reapply the thermal paste?
You never told us what clock/voltage your using and what temps your seeing.
Main Rig:-
Server:-
I'll try to turn down the voltage until it fails and if I can't get a safe voltage on 4,8 I'll turn it down. I hit a max temp of 66C while testing, but I don't really know what to use while stability/stress testing
Desktop Rig:
Just now, kofgokhan said:
I think I was below 1.35v.
80c @ 1.35v with an H115i. Yeah something is very wrong.
Remove the block, clean CPU and block with isopropyl, reapply TIM and try again.
Main Rig:-
Server:-
