cablemod makes some that are compatible I believe
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/692303-led-case-strips/#findComment-8878613
Cablemod widebeam are the best led strips out there in my opinion, but theyre also very bright (atleast for the red version). So if you're looking for something more subtle, youll need either a regulator or another brand
CPU: Intel Core i9-10900K  MOBO: ROG MAXIMUS XII FORMULA GPU: 2080ti Hall of Fame 10th anniversary limited edition  PSU: Asus ROG THOR 1200W  COOLER: Optimus foundation black acetal RADS: 3x EKWB CoolStream PE 360  LOOP: EKWB torque HDC fittings / EKWB ZMT 15,9/9,5mm / EKWB CryoFuel Clear MONITOR: Acer predator X34
https://linustechtips.com/topic/692303-led-case-strips/#findComment-8878652
3 minutes ago, InsertName said:
I have the same case. Use the phanteks led strip. You can utilise the built in RGB hub.
yeah i know. you are only restricted to the colors the case provides tho and with the aura motherboard you can chose any color.
https://linustechtips.com/topic/692303-led-case-strips/#findComment-8878725
I have a ASUS mobo (Maximus VIII Formula) with an Aura header and I use a cable mod light strip, but I don't recommend it. Despite claims to the contrary, the colors do no sync well at all. When it's green on the light strip, it's blue on the mobo, etc. Right now I just set them both to a static color and try to match them as best as I can :(
https://linustechtips.com/topic/692303-led-case-strips/#findComment-8881650
What LED strips are you using? As that is a clear sign of the LED strip being wired differently to the motherboard.
Official Profile for Addon Customs LTD and Custom Acrylics
Addon Customs -
Custom LED Lighting | Single colour and RGB available, hand sleeved | Now making Phanteks Case compatible LED KITS
Custom Acrylics - Custom computer parts | GPU backplates, Fan Grills, NZXT H440 Fascias and PSU covers | 3D printing and Laser Cutting Service available.
https://linustechtips.com/topic/692303-led-case-strips/#findComment-8881846
On 11/18/2016 at 4:26 AM, nielski55 said:
i am searching for led strips for my pc case. i want to plug them in to an asus aura motherboard.
the case is an phanteks enthoo evolv atx tg. does anyone know any good led strips?
check this:
https://linustechtips.com/topic/692303-led-case-strips/#findComment-8884419
