Is there a big difference?
Go to solution Solved by JHY,
nothing much it can only run 4 gpus, but that is unnecessary feature with gtx 10 series.
Is there really a big difference between these motherboards? https://www.asus.com/us/Motherboards/ROG-RAMPAGE-V-EDITION-10/ & https://www.asus.com/us/Motherboards/ROG-STRIX-X99-GAMING/.
I mean, yes I have the money for both but I really don't want to spend $550 on the motherboard unless there's something really special about it but I feel like they're little both the same except for little things.
Cheese
https://linustechtips.com/topic/692300-is-there-a-big-difference/
nothing really, the price and BIOS is basically whats different
Builds:
16 minutes ago, Electronics Wizardy said:
No big difference. You can run 4 gpu's on the rampage extreme.
So basically only difference is like how many gpus it can take everything else like the over clocking features, Asus programs etc are the same
Cheese
That was you thousandth post
Specs v-v
Cpu: Ryzen 9 3900x @ 1.1v / Motherboard: Asus Prime X570-P / Ram: 32GB 3000Mhz 16-16-16-36 Team Vulcan (4x8GB) / Storage: 1x 1TB Lite-on EP2, 2x 128GB PM851 SSD, 3x 1TB WD Blues / Gpu: GTX Titan X (Pascal) / Case: Corsair 400c Carbide / Psu: Corsair RMi 750w / OS: Windows 10
I'm lonely, PM me to be my friend!
