Hey guys,
I plan to build PC for GPU rendering in Octane/ 3D work. I wanted to ask, that CPU 6800k (28 lanes) has enough PCI lanes to run GTX 1080 and GTX 680 without bottleneck? Or should I go with i7 6850k (40 lanes) instead? Here are my specs:
- CPU - i7 6800k
- CPU Cooling - Noctua NH-L9x65
- MOBO - ASUS X99 - A II ATX LGA2011-3
- RAM - Crucial Ballistix Sport LT 64GB DDR4 2400
- GPU - MSI GTX 1080 (for rendering in octane) and GTX 680 for system graphics. No SLI.
- SSD - Samsung 950 PRO 256GB M.2-2280 Solid State Drive
- HDD - 3x 3.5" 7200RPM
- Case - Corsair 300R
- PSU - Super Flower Leadex - 80Plus Gold - 750W
Thanks!
https://linustechtips.com/topic/691468-pci-lanes-advice/
You can run SLI 1080s on a 6700K. You don't need X99 for 2 GPUS.
If you want X99, the 6800K will be just fine.
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/691468-pci-lanes-advice/#findComment-8868692
11 minutes ago, wrathoftheturkey said:
you can't run them both in the same system at the same time on the same program, can you?
You'll be fine, but approaching the limit. PCIe gen 3 16x vs 8x really isn't that big of a deal anyways
I dont want them to run in SLI. Gtx1080 will be only for rendering(Octane) and gtx680 for system graphics.
https://linustechtips.com/topic/691468-pci-lanes-advice/#findComment-8868867
Doubtful, but they plan on using the older 680 as the primary system display's adapter anyways.
Come Bloody Angel
Break off your chains
And look what I've found in the dirt.
Pale battered body
Seems she was struggling
Something is wrong with this world.
Fierce Bloody Angel
The blood is on your hands
Why did you come to this world?
Everybody turns to dust.
The blood is on your hands.
The blood is on your hands!
Pyo.
https://linustechtips.com/topic/691468-pci-lanes-advice/#findComment-8868877
1 minute ago, wrathoftheturkey said:
You can just use integrated graphics for that m8. Besides, I'm pretty sure just running a monitor doesn't use up much GPU power at all (I could be wrong on this though)
Sorry I didn't precise. 680 will be also for photoshop 3d apps viewports and it's from my old pc so why not use it :)
https://linustechtips.com/topic/691468-pci-lanes-advice/#findComment-8868914
