Need small efficient PSU
Go to solution Solved by desertcomputer,
32 minutes ago, AlphaGamer46 said:
Should be fine. Someone online used a 160W one with an i5-6500.
52 minutes ago, TheRandomness said:
I'm fairly certain it should include the cables for powering the mobo and whatnot. You will need to buy a power brick though. I'm not too sure which but googling it will help :P
Thanks, i have look at external power supply needed, and see if it worth to get this or just bronze atx 300 watts.
I need relative small 300-400 WATTS and budget minded PSU for PFsense build, I think even 200 watts is well enough for future upgrades as well but it kinda hard to find PSU in Australia. Do you have suggestion? I saw the a options which allow like external PSU 12V 10A to be converted to computer cables such as 24PIN and 1 4 ESP pin and one molex/sata.
Magical Pineapples
https://linustechtips.com/topic/690647-need-small-efficient-psu/
10 minutes ago, TheRandomness said:
Have a look at the HDPLEX 250W. >94% efficient and powered by a power brick :P
Yes this is what I am looking for but ... it like 80 dollars US just for the adapter, does it includes the cables?
Magical Pineapples
https://linustechtips.com/topic/690647-need-small-efficient-psu/#findComment-8859255
29 minutes ago, MrUnknownEMC said:
-SNIP-
https://www.amazon.com/250w-DC-ATX-Power-Supply-Supplies/dp/B00NB6U3TS
How about this?
2017 Gaming PC
Excellent value machine, keeps me going.
CPU: Intel Core i5-6600K | GPU: Nvidia GeForce GTX 1080 8GB | RAM: 16GB DDR4 | Motherboard: MSI Z170A XPOWER GAMING TITANIUM
PSU: Casecom 600W PSU | Case: Corsair Graphite 230T | SSD: Samsung 850 EVO 250GB | HDD: 3TB WD Blue
Dell XPS 15 9560
Beautiful laptop, in a stunning form factor.
CPU: Intel Core i7-7700HQ | GPU: Intel HD Graphics 630/Nvidia GeForce GTX 1050 (not mobile, full GPU) | RAM: 16GB DDR4 | SSD: 512GB SK Hynix SSD
Display: 4K IPS 100% Adobe RGB Touch Panel | I/O: Two USB 3.0 with PowerShare, HDMI, 3.5mm Headphone Jack, SD Card Slot, and Thunderbolt 3 USB-C
Samsung Galaxy S8 64GB | Samsung Galaxy Tab S2 9.7 32GB
https://linustechtips.com/topic/690647-need-small-efficient-psu/#findComment-8859264
Magical Pineapples
https://linustechtips.com/topic/690647-need-small-efficient-psu/#findComment-8859268
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/690647-need-small-efficient-psu/#findComment-8859285
2017 Gaming PC
Dell XPS 15 9560
https://linustechtips.com/topic/690647-need-small-efficient-psu/#findComment-8859323
Magical Pineapples
https://linustechtips.com/topic/690647-need-small-efficient-psu/#findComment-8859399
