Currently im thinking of getting rid of my ps4 and starting up with a gaming pc i have a budget around £600 and i already have a monitor, os and key board and mouse.This is what I've come up with so far:
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  (£105.59 @ Novatech)
Motherboard: MSI H170 Gaming M3 ATX LGA1151 Motherboard  (£88.99 @ Overclockers.co.uk)
Memory: Corsair Vengeance LED 16GB (2 x 8GB) DDR4-2666 Memory  (£83.99 @ Ebuyer)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£44.13 @ Amazon UK)
Video Card: MSI Radeon RX 470 4GB Gaming X Video Card  (£191.99 @ Ebuyer)
Case: Corsair SPEC-ALPHA ATX Mid Tower Case  (£79.99 @ Amazon UK)
Power Supply: EVGA 430W 80+ Certified ATX Power Supply  (£34.99 @ Novatech)
( any recommendations or tips on my first time?)
https://linustechtips.com/topic/690348-plans-on-my-first-build/
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  (£170.99 @ Novatech)
Motherboard: MSI H110M Pro-VD Micro ATX LGA1151 Motherboard  (£49.93 @ More Computers)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  (£41.99 @ Novatech) - go for the one stick version
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB WINDFORCE OC 6G Video Card  (£232.98 @ Ebuyer)
Case: Cooler Master N200 MicroATX Mini Tower Case  (£44.37 @ Amazon UK)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£49.99 @ Novatech)
Total: £634.38
Generated by PCPartPicker 2016-11-13 19:27 GMT+0000
30 pounds more but way better performance
get an extra 8gb of ram when you can afford it
https://linustechtips.com/topic/690348-plans-on-my-first-build/#findComment-8855908
4 minutes ago, Raahil786 said:
Snip
You can get a 480 4GB or 1060 3GB for about the same price as your desired 470, and both of those cards are going to be a fair bit better than the 470.
https://uk.pcpartpicker.com/product/6898TW/gigabyte-radeon-rx-480-40gb-g1-gaming-video-card-gv-rx480g1-gaming-4gd
https://uk.pcpartpicker.com/product/Jt7CmG/zotac-geforce-gtx-1060-3gb-mini-video-card-zt-p10610a-10l
You should also consider investing in a better PSU, and maybe an SSD. you can shave some cost off of your case, motherboard, and RAM in order to allocate funds for that if need be.
https://linustechtips.com/topic/690348-plans-on-my-first-build/#findComment-8855914
14 minutes ago, Raahil786 said:
Snip
A build like this would probably be better bang for the buck, and has an SSD which will be hugely beneficial for day to day OS navigation: http://uk.pcpartpicker.com/list/sdwvbj
If you can spare a bit more cash, you may want to consider getting a 1060 6GB or RX 480 8GB (depending on what is better priced) which will perform a bit better than the 1060 3GB. You may also wish to fork over a bit more money for motherboard if it doesn't have the connectivity/features you want, but that isn't going to affect your performance at all, so you may wish to consider stepping up to an i5 i6400/6500 instead if performance is what you're after.
all that being said, there is nothing "wrong" with your initial build. you chose many good parts, its just that at your pricerange, if we readjust how much we spend on certain components you can end up with a stronger computer for your money, but its your money... feel free to spend it on whatever you want =)
https://linustechtips.com/topic/690348-plans-on-my-first-build/#findComment-8855959
PCPartPicker part list: http://uk.pcpartpicker.com/list/4XNw7h
Price breakdown by merchant: http://uk.pcpartpicker.com/list/4XNw7h/by_merchant/
CPU: Intel Core i5-6400 2.7GHz Quad-Core Processor  (£170.99 @ Novatech) Better CPU, you will have less stuttering and more fps
Motherboard: Asus H110M-K Micro ATX LGA1151 Motherboard  (£47.99 @ Amazon UK)
Memory: G.Skill Ripjaws V Series 8GB (2 x 4GB) DDR4-2666 Memory  (£40.99 @ Novatech)
Storage: Toshiba 2TB 3.5" 7200RPM Internal Hard Drive  (£38.33 @ Aria PC)
Video Card: Gigabyte GeForce GTX 1060 6GB 6GB WINDFORCE OC 6G Video Card  (£232.98 @ Ebuyer) Significantly better than the 470
Case: Phanteks ECLIPSE P400 ATX Mid Tower Case  (£57.27 @ CCL Computers) Great case for the money
Power Supply: XFX TS 430W 80+ Bronze Certified ATX Power Supply  (£33.54 @ Eclipse Computers) Better quality than the one you chose for the same price
Total: £622.09
Generated by PCPartPicker 2016-11-13 19:39 GMT+0000
https://linustechtips.com/topic/690348-plans-on-my-first-build/#findComment-8855997
3 hours ago, NicekillBG said:
the case isnt as good as the price says
better get a cheaper case
also save up just a little and get the 6500(i5) you wont regret it
also what reso is your monitor
My monitor is a 1920 x 1080p resolution and i might aswell get an i5 i suppose
https://linustechtips.com/topic/690348-plans-on-my-first-build/#findComment-8857053
