Low GPU usage and Low FPS
Solved by MANIDY inc,
1 hour ago, Sergio Urtiz said:i have a 144hz monitor thats the reason i am concerned. I've seen people get much more FPS thats the reason i am sad.
yes but playing on FPS over 60 is really pointless, it opens you up to FPS drops and screen tearing and all that.
i see that you want to get the most performance you can and make sure you have no issues, and since you bought a prebuilt you can contact the ibuypower support and troubleshoot with them
