Macbook Pro really high CPU load temp
So I got a top of the line 2013 MBP for $300 which is why I bought it.
So while rendering a video or doing a stress test the CPU can get up to 98c! I've posted another topic on this with no sourced or direct answer. Is this normal? Will cleaning it or reapplying thermal paste help at all? I've done some research and other people are having problems like this. Will this degrade the life of the Macbook? I don't know what to do at this point and it's just stressing me out.
i like linux
https://linustechtips.com/topic/689343-macbook-pro-really-high-cpu-load-temp/
Reapply the thermal paste and tighten the screws for the heatsink
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
Give it a good old clean out, and reapply thermal paste.
If that doesn't work, well... it's a MacBook. There's only so much you can do about high temps.
Other systems I've built:
I'll order the things tomorrow then.
i like linux
2013 MacBook Pro, sounds like the retina version already.  The CPU is soldered onto the logic board.  The only thing you can do is open up the bottom cover, use a can of compressed air to dust out all the vents, fans, heatsinks, etc.
That is not dead which can eternal lie.  And with strange aeons even death may die. - The Call of Cthulhu
A university is not a "safe space". If you need a safe space, leave, go home, hug your teddy & suck your thumb until ready for university.  - Richard Dawkins
You can take heatsinks off
AXIOM
That's a Macbook Pro for yea lol  I would clean it with isopropyl alcohol and reapply some thermal paste.
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
Ahh right, but it probably won't do much by reapplying thermal paste.  The paste Apple uses is already of a decent quality.  But dusting out the vents and fans will help.  I dust mine out every year.
Can you use isopropyl on delidded/exposed CPUs?
i like linux
I try and do it at least once a month.
This is also a used Macbook.
i like linux
Yea.. I've done it on literally thousands of computers.
It's non-conductive, and it takes thermal paste right off. Just put a little on a napkin and wipe the old thermal paste away.
Sure if you live in a place where the air is pretty dusty that it requires a monthly cleaning.  I don't.
I use my MBP for work, I'm always working on servers, and in racks which can be dusty.
I use mine for work too, but we work in totally different types of environments and jobs.
