Crysis 2 running at 24FPS
Go to solution Solved by Russboy360,
Just found a way to sort it, start the game in windowed then full screen it on in game.
Sorry I should have looked first
I am trying to play Crysis 2 on my PC, my display is an LG 32 TV, (LG 32LK450U)
The TV support a mode called Real Cinema 24p, which sets the refresh rate 24hz
When playing Crysis 2 I use V-Sync, for some reason Crysis 2 is V-Syncing at 24hz making it unplayable
Is there a way of playing with V-Sync on at 60hz?
https://linustechtips.com/topic/68910-crysis-2-running-at-24fps/
Is it only Crysis 2 that does this?
Alternatily you could play without VSync. Screen tearing isn't that big of a problem in modern games.
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/68910-crysis-2-running-at-24fps/#findComment-945010
Have you tried disabling the "Real Cinema 24p" setting if your TV allows you to?
i5 3570k @ 4.2GHz | ASUS STRIX 970 | MSI Z77A-G43 | 16GB Corsair Vengenace 1600Mhz | 128GB/256GB Samsung 840 Pro | 2x 240GB Intel 335 Series | 1TB WD Black | Corsair 650TX | CM Storm Scout 2 Advanced (Ghost White) | Win 10 Pro
https://linustechtips.com/topic/68910-crysis-2-running-at-24fps/#findComment-945012
are far as i know it is only Crysis 2
The Real Cinema 24p can't be disabled
And in Crysis 2 tearing is VERY noticeable
If Real Cinema cannot be disabled you are out of luck :(
Sorry dude, but I think you need a new screen...
Tor
Corsair Obsidian 650D - Intel 4770K CPU - Gigabyte G1 Sniper 5 - ASUS GTX 780 Direct CU 2 - Kingston Beast Hyperx Beast 16 GB RAM -  Corsair AX 1200i PSU - Samsung EVO drive 750 GB - Corsair AF series 120mm fans - Corsair H100i - Razer Blackwidow Ultimate 2013 edition - Razer Ouroboros - Razer Manticor - Windows 7 - Beyerdynamic MMX 300
https://linustechtips.com/topic/68910-crysis-2-running-at-24fps/#findComment-945035
I will be getting a new screen soon, hopeful a 3D one, any recommendations?
Wait a little while for 4K monitor price to come down!
CORSAIR AIR 540 | CORSAIR AX1200i | GIGABYTE 990FXA-UD7 REV 3.0
AMD 8350 Vishera 5.0GHz @ 1.525V | CORSAIR H100i Push/Pull | CORSAIR VENGEANCE 32GB  DDR3 1600Mhz
KINGSTON HYPER 3K 120GB (2) RAID 0 | SEAGATE BARRACUDA 1.5TB (4) RAID 5 | EVGA GTX 770 4GB FTW ACX (SLI) | CORSAIR AX1200i
https://linustechtips.com/topic/68910-crysis-2-running-at-24fps/#findComment-945153
Will a 4k monitor run on a EVGA GTX 760 4GB FTW, plus I like the idea of 3D
lolno
"Say it, do it, preach it, shout it, but never, absolutely never, believe your own bullshit"
Credited with the whole female avatar trend
Your thoughts here http://linustechtips.com/main/topic/67178-your-top-three/
https://linustechtips.com/topic/68910-crysis-2-running-at-24fps/#findComment-945287
it will run a 4K monitor but not with games running on it unless it's a non graphic intensive game or with very low settings. Maybe Minesweeper should be OK.
https://linustechtips.com/topic/68910-crysis-2-running-at-24fps/#findComment-945340
