i have a seagate external hard drive - that has a samsung spinpoint 2000LM003 2tb hdd in it - suddenly it stopped working - before, sometimes it would work if i moved it around and put it vertically or horizontally - I don't know if it's the sata adapters issue or the hdd - no clacking sounds in the hdd except for startup - also, the disk sounds like it's spinning fine
https://linustechtips.com/topic/688111-dead-hdd-help-me/
"Siri, find me the nearest funeral home."
"I have found several locations, the closest is twenty meters away. Would you like to navigate to the "Trash"?"
"Yes, please"
"You will arrive at your destin... You have arrived at your destination."
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/688111-dead-hdd-help-me/#findComment-8832069
1 minute ago, ARikozuM said:
"Siri, find me the closest funeral home."
"Yes, please"
i think it might be my adapter
https://linustechtips.com/topic/688111-dead-hdd-help-me/#findComment-8832073
Clicking indicates that the actuator has become worn and is struggling to work. No clicking would mean that the spindle has worn down. My suggestion is to find a professional who can get the data off. The other choice is getting it to function and backing everything up.
Edit: I would also check the SATA power or data cables.
https://linustechtips.com/topic/688111-dead-hdd-help-me/#findComment-8832086
6 hours ago, gtx1060=value said:
~snip~
Hi there :)
What is the external drive's model? What but are you using to connect the drive to the PC (SATA to USB, simple USB or other type of cable)?
Clicking sounds are typically a sign of a problem in the drive and it is suggested to back your data up ASAP and then replace the drive. Have you checked your drive's S.M.A.R.T. data? I would recommend using some diagnostic tools from the manufacturer and see if the drive is detected and if it passes those tests.
Using different cables, ports and testing the drive on another computer is also a good idea.
Feel free to ask if you have any additional questions!
Captain_WD.
If this helped you, like and choose it as best answer - you might help someone else with the same issue. ^_^
WDC Representative, http://www.wdc.com/
https://linustechtips.com/topic/688111-dead-hdd-help-me/#findComment-8833381
