Aio refurbished
Go to solution Solved by MorganO,
1 minute ago, That-Something_ said:
5 years
go for it, refurbished means probably in this case they cleaned the radiator  and fans, if still doubtful ask them if they know what was 'refrubished'
Should I go refurbished corsair h115i for $90.00 Insted of a new one at $150.00?
whos it refurbished by?
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/687985-aio-refurbished/#findComment-8830777
Just now, That-Something_ said:
My local Frys  electronics
warranty inc?
https://linustechtips.com/topic/687985-aio-refurbished/#findComment-8830786
5 years
https://linustechtips.com/topic/687985-aio-refurbished/#findComment-8830801
If you don't mind risking your PC components then sure.
https://linustechtips.com/topic/687985-aio-refurbished/#findComment-8830802
refurbished normally means restored to like new status. Though they tend to have a lesser warranty.
                     ¸„»°'´¸„»°'´ Vorticalbox `'°«„¸`'°«„¸
`'°«„¸¸„»°'´¸„»°'´`'°«„¸Scientia Potentia est  ¸„»°'´`'°«„¸`'°«„¸¸„»°'´
https://linustechtips.com/topic/687985-aio-refurbished/#findComment-8830894
"restored" means there was something wrong in the first place, which is a bad thing for something that contains liquid and goes inside a computer.
https://linustechtips.com/topic/687985-aio-refurbished/#findComment-8830917
