Ps4 Pro sized Case
Go to solution Solved by dizmo,
Dr Zaber Sentry is going to be your closest bet.
I would imagine something like the Fractal design Node 202 is about as close as you're gonna get. Maybe a Lian-Li case?
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
https://linustechtips.com/topic/687646-ps4-pro-sized-case/#findComment-8827137
There was one that was Kickstarted that can basically be the bare minimum volume for a Mini ITX system and a 12" graphics card, but I forgot the name of it. Otherwise the Fractal Node 202 or Silverstone's RVZ02 is about the smallest you can get, at least if you want a full size card.
There are smaller Mini-ITX cases out there, like Antec's ISK-110, but it won't fit anything other than the motherboard and a drive.
https://linustechtips.com/topic/687646-ps4-pro-sized-case/#findComment-8827145
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/687646-ps4-pro-sized-case/#findComment-8827168
