1 minute ago, Dawson Wehage said:
Oh. Virtual Machines, Multiple at a time. I do recommend this server now if your going to be multitasking like crazy.
not may just  nas and one once in while to test out os like window sever or Ubuntu
IBM System x3650 M3 Server 2x) Six Core X5650 2.66GHz 64GB RAM 4x146GB SAS RAID
$279.99
+$60.00 shipping
https://linustechtips.com/topic/687544-home-sever-and-nas/#findComment-8826030
1 hour ago, m2234323 said:
how to decide if I should buy one or buld one
If you are having trouble deciding between building a server yourself or buying a secondhand unit perhaps consider some of the pros and cons of each.
Buying secondhand;
- Cheap parts and easy to find fully configured servers or computers, ready to go.
- Parts may be old, which could make it susceptible to failure, slow or inefficient (i.e. high power draw, excess heat or noisy)
- Often times you will come across servers with proprietary connectors or adapters, requiring you to find and source identical replacement parts if something fails.
- You may be limited in expansion options, some boards or parts may not support the features you require(i.e. old RAID cards often don't support more than 2TB per drive, or you're limited to 2.5" in a particular case, or the motherboard only supports legacy standards like PCI-x)
Buying New;
- Expensive
- Can choose parts to exact specifications
- Often desktop parts are made to, or you can easily choose, standards that are interchangeable and easily replaceable in the event of failure
- Newest parts run cooler and more efficiently.
do it have to be XEON  cpu for home use
No, It does not have to Xeon for the use case you are suggesting. Normal desktop parts a reliable enough for a home server, even running 24/7. The advantage of Xeon's comes from added reliability, through extensive testing and validation, the addition of ECC RAM, their efficiency and the ability to scale beyond a few cores and a single processor.
If you want a fast, cheap computer to run as a NAS and have enough horsepower left over to experiment with and with reasonable expansion options, I would suggest something along the lines of a secondhand workstation. You can often find them cheaply and they have support for multiple drive types and add-in cards while being powerful enough for your needs, however they also are often proprietary in size or connectors. That said, you can also often find cheap parts to transplant into and maintain the system in the event of a motherboard failure or PSU failure or the like. Just try and go for a common systems for maximum part availability.
Something like this (Z600, Z800 series are good too) might take your fancy, please also note you can get cheap bay accessories if you wish to expand available drive spaces.
http://www.ebay.com/itm/HP-Workstation-Z400-PC-Desktop-Intel-Xeon-W3520-2-67GHz-16GB-500GB-DVDRW-W7P-/122211626065?hash=item1c74616c51:g:kkUAAOSwLF1X8rhm
A bit higher-end but with 2 CPUs and a graphics card, if you wish to experiment
http://www.ebay.com/itm/HP-Workstation-Z600-2x-QC-Xeon-E5520-2-27GHz-8GB-RAM-500GB-HDD-FirePro-2270-/371689565699?hash=item568a6cae03:g:JbUAAOSwGIRXYvdY
Bay expansion (on the cheap)
http://www.ebay.com/itm/can-set-5pcs-3-5-SATA-SAS-HDD-PC-Host-Case-Hard-Drive-bay-Cage-Tray-Caddy-Rack-/381748892628?hash=item58e201d3d4:g:hGIAAOSw~OdVdpaQ
High-end hotswap
http://www.ebay.com/itm/NORCO-SS-500-5-Bay-SATA-SAS-Hot-Swap-Rack-Module-/122215117233?hash=item1c7496b1b1:g:RxkAAOSwB09YIIH1
EDIT: Also take into consideration age of parts. Generally speaking, looking up the processor model on Intel ARK is good enough to ballpark the age of the system, and also account for the cost of replacement parts vs the cost of new parts. For example if supply is plentiful and you could buy two or more parts for the cost of a new one it makes sense to go secondhand for personal use.
Still, pay very close attention to compatibility with secondhand server/workstation parts. I can't stress this enough. For example, that Z400 PSU looks like it's ATX sized, but its not and it doesn't have standard ATX power wiring on the end, but you can plug an ATX PSU into the motherboard, though you might fry it.
You could also look at secondhand desktop machines as well; they often have better compatibility with commercial of the shelf parts, however I often find it's harder to find good deals as most are overvalued and they often have the same trappings of using custom size form factors when purchased from manufacturers; perhaps something like this http://www.ebay.com/itm/Dell-OptiPlex-780-Desktop-Core-2-Quad-Q9400-2-66GHz-4GB-DDR3-250GB-WIN7-COA-Used-/371782897625?hash=item568ffccfd9:g:hKgAAOSw2GlXJN5v
You could also cobble a machine together from component parts but this is often quite difficult secondhand, best bet for this option would be to scrounge around a secondhand computer parts stores and get a Motherboard, CPU, RAM and case to fit. Afterwards buy HDD's, PSU (always if you can, buy good PSU's new), any extras you might need- GPU etc - and your flavor of Operating System.
https://linustechtips.com/topic/687544-home-sever-and-nas/#findComment-8826398
Buying secondhand;
Buying New;
- Expensive
High-end hotswap
or this http://www.ebay.com/itm/SuperMicro-933T-2x-AMD-Opteron-250-2-4Hz-8GB-RAID-15-Bay-SATA-Storage-NAS-/112165618097?hash=item1a1d9781b1:g:baMAAOSwLF1X~uGR
would it work
https://linustechtips.com/topic/687544-home-sever-and-nas/#findComment-8826659
2 hours ago, m2234323 said:
A little bit of research reveals that this particular system is a long out of date dual processor, single core design from 2004. They're 90nm fab process running at 2.4Ghz, the 15x 3.5" drive bays are appealing, however it is in the 3U server form factor and unless you have a server rack, may be unwieldy to store or use.  The system runs 8GB of DDR SDRAM, likely 133Mhz. The expansion card running to the front back-plane is an LSI Logic MegaRAID SATA300-8X which runs at 300MB/s on a PCI-X bus and does not support greater than 2TB per drive.
This may or may not fit your needs or wants, however without more information about your usage or plans I could not say either way.
Edit: Forgot to quote. Oops.
https://linustechtips.com/topic/687544-home-sever-and-nas/#findComment-8827167
it is very hard to decide which one to get
https://linustechtips.com/topic/687544-home-sever-and-nas/#findComment-8830253
23 hours ago, m2234323 said:
have 4 hard drive  aready  on 4 tb one 500gb 2 320 gb
21 hours ago, m2234323 said:
If you bought the server you linked (The one with the dual AMD Opterons from 2004) you would be unable to use the 4TB drive you already have on hand for storage, as the RAID card in this particular server does not support over 2TB.
https://linustechtips.com/topic/687544-home-sever-and-nas/#findComment-8831801
How to decide how power full how many hard drive did the computer you show have space for
or will this work http://www.ebay.com/itm/2U-Server-8x-3-5-Bay-SATA3-6GB-s-JBOD-FreeNAS-Server-X8DTI-F-2x-Xeon-E5620-24GB-/142166511422?hash=item2119c8cf3e
https://linustechtips.com/topic/687544-home-sever-and-nas/#findComment-8831833
