Hey Guys!
So I'm looking to RGB my case (currently red), My problem is that the only rgb strips available in NZ are Deepcool RGB 350's, which are only 300mm. I have Zalman z11 plus (http://www.zalman.com/contents/products/view.html?no=334) and I'm wanting to not only light up the internal components but also the top fins and if possible the front fan area. So I guess my question is can I use multiple strips and IR receivers from one remote? Any ideas? Much appreciated!
- Samuel
Samuel Edwards
- IT Engineer and Media Producer -
Religious theology diploma and over half a dozen certificates in Advanced Computing and IT.
Current Project:   Mineral Oil Cooled PC
Just trying to be friendly and help where I can. Have yourself a great day!
Use @SamuelJE for friendly tech help :)
Main PC - "The Genesis"
Mobo   -   Gigabyte GA-H170-Gaming 3
CPU     -   intel i5-6600K 4Ghz on water
GPU     -   MSI GTX970 "Red Dragon"
Case    -   Zalman Z11 Plus (Custom RGB Obviously, It's 2017 bro...)
OSD     -   Crucial 275GB M.2 SSD
SSD     -   Crucial 250GB SATA SSD
HDD    -    4TB WD Green x 2
Disp     -   LG ultra wide Gaming Monitor
Secondary PC - "Jonah"   (Mineral oil PC)
Mobo   -   Gigabyte GA-B250-DH1
CPU     -   intel i5-7500 Under Oil
GPU     -   Nvidia GTX 660 (Favorite and first ever GPU)
Case    -   A Fish Tank W/ Custom Engineered Mounting System (Custom RGB Obviously, It's 2017 bro...)
HDD    -    2TB WD Green
https://linustechtips.com/topic/687515-multiple-rgb-led-strips/
I use a 1m strip to light up my case. no need for multiple strips unless you want your case to look like a Xmas tree. Your case doesn't have a huge window anyway
You do have options, NZ websites don't list their entire inventory online. I recently purchased a Phanteks one that matched my case; i had to do a search by manufacturer to find it; it wasn't categorized.
You can always go on aliexpress to find stuff like RGB LEDs
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/687515-multiple-rgb-led-strips/#findComment-8825724
I'm pretty sure there are a couple options for multiple strips, can't remember off hand as I had to keep myself from looking to hard at it (so much money would vanish if I got started)
But I think the NZXT hue+ give's the best control over multiple strips, in comparison everything else has simple preset's.
Nothing wrong with the preset's but the hue+ is the pinnacle of current rgb strip customization.
I have the cablemod rgb setup and I believe it can handle 4 strips which is enough for basically any case.
The RGB rabbit hole goes deep, it's pretty new but there is a lot emerging.  corsair has their new RGB fan series wich is AMAZING.
One reason I have held off is there is nothing universal, you can't get your RGB keyboard, mouse, fan's and strips to work together.  Again that's because it's a budding technology.  If there was a standard behind all of it I would save up and go bonkers on it.
So the general idea is if you want RGB right now, I would find something that meet's your needs IE: multiple strip's with a remote.  If you're looking for the best you'll spend a ton of money and be let down as the market improves.  So I would suggest the cablemod's RGB strips with remote.
edit: I have seen little snippit's here and there about CAM software...... something to look into, but I'm not sure what it is.
Audio go Brrrrrr
https://linustechtips.com/topic/687515-multiple-rgb-led-strips/#findComment-8825725
13 minutes ago, SamuelJE said:
Hey Guys!
- Samuel
There are other RGB strips available in NZ.
Computer Lounge sells 3 different ones
http://www.computerlounge.co.nz/components/componentview.asp?partid=27047
and mighty ape has some other options
https://www.mightyape.co.nz/computers/components/lighting-solutions/all?page=2
CPU: Intel i7-4790K @ stock for now --- RAM: Corsair Vengeance 16Gb --- MOBO: Asus Maximus VII Formula --- GPU: MSI Gaming GTX 980ti --- PSU: Corsair AX860i  ---  Storage: Samsung 850 250gb(OS), 3x Western Digital Blue 3tb (one for game and programs, two for media), 3tb WD Green(somewhat backup) and a Crucial M550 120gb SSD (caching games and programs drive)  --- Case: Fractal Define R5 --- Cooler: Corsair H100i with Noctua 2000rpm, Industrial Fans --- OS: Windows 10 --- Monitor: Asus PB298q + AOC l2260SWD --- Mouse: Logitech G502 Spectrum --- Keyboard: Corsair K70 (Cherry MX Red) Red LED's --- Audio: Audio Engine A2's (yes the originals), Sennheiser HD 58x Jubilee Audio-Technica ATH-AD900x, Audio-Technica ATH-M50x, Ant Lion Mod Mic V4 --- Laptop: Dell XPS 9750
https://linustechtips.com/topic/687515-multiple-rgb-led-strips/#findComment-8825738
1 minute ago, Psittac said:
ohhhhhh is NZ new Zealand? Sorry I didn't understand what it was.  I think everything there get's a MASSIVE markup, guess my advice isn't valid
Yeah it's pretty limited. All good, much appreciated :)
Samuel Edwards
HDD    -    2TB WD Green
https://linustechtips.com/topic/687515-multiple-rgb-led-strips/#findComment-8825756
Yeah thanks :)
I had a look around. Mighty ape has the same as PBtech (which is cheaper there and is about to have a black friday sale) but unfurtunately and extremely rarely the computer lounge has an even worse selection than the others.
Samuel Edwards
HDD    -    2TB WD Green
https://linustechtips.com/topic/687515-multiple-rgb-led-strips/#findComment-8825771
1 minute ago, wONKEyeYEs said:
I have a case that I run two of them in for a total of 4 LED strips.
The Deepcool RGB 350 are great for the price.
One controller can control both units.
Oh yeah? Works just fine with the one remote aye? In time n' all?
Samuel Edwards
HDD    -    2TB WD Green
https://linustechtips.com/topic/687515-multiple-rgb-led-strips/#findComment-8825776
40 minutes ago, SamuelJE said:
Hey Guys!
- Samuel
You can run all those LED strips off a single controller as those usually have a rating of almost 6Amps for the large units which can easily do an entire 5m roll of LED's.
-Moved to Modding Section-
https://linustechtips.com/topic/687515-multiple-rgb-led-strips/#findComment-8825860
Oh yes? So some ghetto wiring? or is there a cleaner easier way?
Samuel Edwards
HDD    -    2TB WD Green
https://linustechtips.com/topic/687515-multiple-rgb-led-strips/#findComment-8825999
Just daisy chain them together to form a longer strip if they have connectors on the ends or get splitters online as they use the standard SMD5050 LED's which are ubiquitous. If you don't mind doing some DIY work you can also get a kit that cut and wire to length yourself.
https://linustechtips.com/topic/687515-multiple-rgb-led-strips/#findComment-8826025
Ok, thanks! I'll see if I can find some splitters online. Trouble is I'd rather not wait a month for them to arrive from China.
Samuel Edwards
HDD    -    2TB WD Green
https://linustechtips.com/topic/687515-multiple-rgb-led-strips/#findComment-8826062
