6 minutes ago, vbutko said:
I only have finished building my pc and when i try to power it on it powers on for few sec and then turns off multiple time ,how can i fix it and make it go atright to the bios ?
Is your cpu fan connected to the cpu fan pin on the motherboard? if nothing is connected to the cpu fan pin it will prevent the computer from starting
https://linustechtips.com/topic/687327-need-help/#findComment-8823489
