I have a 980ti sli configuration and it always worked fine. 1/2 months ago almost any game started heavy stuttering due to low gpus usage, in fact the cards always run low usage but never 99% ( 60/70/80/50 etc ), this is very annoying and it also happens in easy games ( rocket league doesn't go above 200 fps and it keeps stuttering ) and even using a single gpu in any of the pcie slots. I already tried to check temps, install differents drivers, overclocking cpu and ram, kboost, pcie power management, formatting to a fresh os, memtest and checking cpu and ram usage. I think it could be due to a bios/os setting because I already tried everything hardware and driver side but it could be wrong of course.
Any help?
i7 6700k ( stock due to high temps but even clocking it to 4.6ghz makes no effect )
Z170 Pro Gaming
Corsair H100i
Evga P1000
WD Black
Samsung 850 Pro Evo
2x4gb Kingston Savage 2133mhz
Sli 980ti g1 gaming
Haf X
W10 ( last build )
https://linustechtips.com/topic/686970-low-gpu-usage/
Did you reboot your PC? Because it doesn't seem like you did that since you didn't say you did.
AMD FX 6300 @ 4.6 Ghz CRYORIG H7 Asus M5A97 PLUS | HyperX Fury 8 GB DDR3 | PNY CS1311 120gb SSD WD Blue 1TB 7200 RPM EVGA GeForce GTX 950 Superclocked NZXT Source 210 Black EVGA 500B Logitech G Pro HP K3500 Wireless Keyboard |
https://linustechtips.com/topic/686970-low-gpu-usage/#findComment-8819490
How high are the CPU temperatures? Your temperatures shouldn't be that high necessarily with an H100i.
https://linustechtips.com/topic/686970-low-gpu-usage/#findComment-8819504
