why prebuilt tho,some charge for assembly so that might be a saving factor
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
https://linustechtips.com/topic/686764-pre-built-pcs/#findComment-8817456
5 hours ago, Emils B said:
I`m afraid of messing/breaking something
well if you can build something with lego you're good to go
https://linustechtips.com/topic/686764-pre-built-pcs/#findComment-8819139
Don't be. A computer is just a Lego set. Follow the instructions in the motherboard manual and you'll be fine.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/686764-pre-built-pcs/#findComment-8819428
1 minute ago, Emils B said:
well any suggestions
aisle9
and
McHox
 on the lego i buy?
Put @ before someone's name and they'll get a notification ;) @Emils B
Is this a gaming rig? Productivity? What's the primary function it will be used for?
https://linustechtips.com/topic/686764-pre-built-pcs/#findComment-8819456
3 minutes ago, Emils B said:
@aisle9 also i just want it to play something like gta 5 on medium settings and cs:go but that game is already well optimized so if you could as cheap as possible
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  (£92.91 @ Amazon UK)
Motherboard: Asus H110M-K Micro ATX LGA1151 Motherboard  (£47.99 @ Amazon UK)
Memory: Kingston 8GB (1 x 8GB) DDR4-2133 Memory  (£32.99 @ Novatech)
Storage: OCZ TRION 150 240GB 2.5" Solid State Drive  (£59.99 @ Amazon UK)
Storage: Toshiba 2TB 3.5" 7200RPM Internal Hard Drive  (£38.33 @ Aria PC)
Video Card: XFX Radeon RX 480 4GB RS Video Card  (£199.98 @ Ebuyer)
Case: Fractal Design Core 1100 MicroATX Mini Tower Case  (£29.99 @ Amazon UK)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£49.99 @ Novatech)
Total: £552.17
Generated by PCPartPicker 2016-11-07 00:29 GMT+0000
If you need to shave off some cash, part ways with the Toshiba HDD and roll with just the SSD to start. You can always add bulk storage later, but moving your OS onto a new drive sucks. That Toshiba is a killer deal, though.
This can handle GTA V at ultra 1080p, I would think.
https://linustechtips.com/topic/686764-pre-built-pcs/#findComment-8819528
Well thanks, @aisle9 I`ll think about that
No worries. If you need to shave off a little more cash, stepping down to an RX 470 makes sense, but my theory on gaming PCs is that you pick a GPU and build around it. 480 seemed like a natural fit here. :)
https://linustechtips.com/topic/686764-pre-built-pcs/#findComment-8819562
2 minutes ago, Emils B said:
@aisle9 how well do you think it could be overclocked?
The CPU is locked and can't be overclocked. Overclockable CPUs and Z170 motherboards would launch your budget up into the 700GBP range pretty quickly.
From what I've read, RX 480s tend to be pretty solid overclockers. See below.
https://linustechtips.com/topic/686764-pre-built-pcs/#findComment-8819609
If all you're doing is gaming, the stock frequency of the 6100 should be plenty. My main HTPC rig is an i3-6100, and I never once had an issue with it running games like Kerbal Space Program, Overwatch, Skyrim (with crazy mods) or Far Cry 4 (with crazy low resolution).
https://linustechtips.com/topic/686764-pre-built-pcs/#findComment-8819650
@aisle9 also the total is 513.84 if you don`t count the hdd
If 500 is a very hard cap and you don't even have 13GBP wiggle room, I'd lose the SSD and keep the HDD. That's a really good value on 2TB, but your boot and load times will suffer. If you can find the extra 13GBP, I'd keep the SSD.
https://linustechtips.com/topic/686764-pre-built-pcs/#findComment-8819659
Just now, Emils B said:
@aisle9 so how long do you think this pc would be able to hold up like years with all new games coming out
You're set for a good while. Here's why:
Upgrade path. The i3-6100 is the base-level Core CPU for Skylake. Ivy Bridge i7-3770 CPUs, which are (don't count Broadwell) two generations behind are selling on UK eBay for 152GBP. If you hang in there with the 6100 for a couple of years, you can snag a used i7-6700 (or i7-7700) off of eBay and buy your CPU two or three more years past that. By the time your i3 is showing its age, you'll be able to just drop a locked Skylake or Kaby Lake i7 in there in its place.
GPU. The RX 480 will be a solid 1080p card for at least a couple of years, probably longer. An RX 470 or GTX 1050 Ti might not have that same longevity.
https://linustechtips.com/topic/686764-pre-built-pcs/#findComment-8819685
and also @aisle9 what about cooling
The stock cooler that comes with the i3-6100 is fine. For the most part, you only need aftermarket cooling if you're overclocking.
https://linustechtips.com/topic/686764-pre-built-pcs/#findComment-8819693
