I've read up on forums but was unsuccessful. My AMD x4 845 keeps jumping around on its speed from 2.60GHz to 3.00 to 3.50 when used.
I want it to stop fluctuating its voltage and its speed and keep its multiplier on one number, as it's annoying. I wouldn't mind more fan noise from the heat as I use fairly loud speakers/Headphones all the time.
What options would i have to change in the UEFI to stop it?
MB:F2A68HM-H
AMD Athlon X4 845
8GB DDR3 1600
https://linustechtips.com/topic/686680-cpu-speed-fluctuating/
Its just downclocking itself to save power i believe. I think you can change this in the windows power settings, not 100% sure.
|Casual Rig| CPU: i5-6600k |MoBo: ROG Gene  |GPU: Asus 670 Direct CU2 |RAM: RipJaws 2400MHz 2x8GB DDR4 |Heatsink: H100i |Boot Drive: Samsung Evo SSD 240GB|Chassis:BitFenix Prodigy |Peripherals| Keyboard:DasKeyboard, Cherry MX Blue Switches,|Mouse: Corsair M40
|Server Specs| CPU: i7-3770k [OC'd @ 4.1GHz] |MoBo: Sabertooth Z77 |RAM: Corsair Vengeance 1600MHz 2x8GB |Boot Drive: Samsung 840 SSD 128GB|Storage Drive: 4 WD 3TB Red Drives Raid 5 |Chassis:Corsair 600t
https://linustechtips.com/topic/686680-cpu-speed-fluctuating/#findComment-8816600
10 minutes ago, KooKooMan117 said:
-snip-
It's doing that to save power since you aren't putting the CPU under full load. If you understand that you're pretty much just running the CPU at full blast even for lighter workloads, then:
Go to power options -> Change plan settings -> Change advanced power settings -> Processor power management (scroll down) -> Minimum processor state -> Change to 100%.
Your CPU will stay at the highest clock speed. Though please reconsider since it saves you power...
https://linustechtips.com/topic/686680-cpu-speed-fluctuating/#findComment-8816606
1 minute ago, Curious Pineapple said:
All CPU's do this, it's to save power, you don't need all the CPU's performance for light loads, so they down-clock.
I want to disable it completely. It's alright if it uses a lot more power.
https://linustechtips.com/topic/686680-cpu-speed-fluctuating/#findComment-8816608
1 minute ago, scottyseng said:
It's doing that to save power since you aren't putting the CPU under full load. If you understand that you're pretty much just running the CPU at full blast even more lighter workloads, then:
Its was already set to 100% and still fluctiates.
https://linustechtips.com/topic/686680-cpu-speed-fluctuating/#findComment-8816610
It also generates more heat, and puts more load of the mainboards power delivery circuits, as well as the power supply. You can disable cool and quite don the BIOS and that will keep it running at 100% if you want it to.
https://linustechtips.com/topic/686680-cpu-speed-fluctuating/#findComment-8816617
Already disabled. Still does it.
https://linustechtips.com/topic/686680-cpu-speed-fluctuating/#findComment-8816707
Just now, System Error Message said:
all CPUs do this but sometimes a CPU does this even on load. I've noticed this when hosting a game server and have had to disable power savings and speedstep equivalent on AMD.
what's the equivalent on AMD?
https://linustechtips.com/topic/686680-cpu-speed-fluctuating/#findComment-8816835
dunno, i just googled it. On my fx CPU it can host space engineers well but it kept its clocks at 1.3Ghz making the game run in slow motion. after disabling it i got the full frequency and full speed in the game.
https://linustechtips.com/topic/686680-cpu-speed-fluctuating/#findComment-8816846
