build for my mom
yhea im stupid
uhm i edited a little bit and the case was only a side panel mistake on the website
http://de.pcpartpicker.com/p/1T281
a fx 4130 is going to cut it i dont have much money to spend
i also just need a gpu with that and thise one is strong enough
>>>>What games<<<<<
it may be worth getting a 6670-7750-7770 depending what games shes looking to play.
also whats your maximum budget? how many usb ports do you need? that board has 4 usb2.0 and 2 usb3.0 PLUS another usb2 and usb3 on the case.
we need information before we can give you the best build for your needs.
also chose between the black or white
I have done a review (on facebook) and I can say its best case for the money, I would not buy a coolermaster they, they are not all they claim to be (sorry but its the truth, theyre not bad but theyre not good and "meh" isnt good enough)
I REALLLYY do not reccomending spending less and cheaping out on anything here (maybe the wifi card), if you dont buy something or you try to cheap out on something now it will cost you more later....for instance
powersupply-blows up and you either have to buy another or it might kill your pc
graphics card-gaming sucks and you have to buy another one thats even more expensive
case-you buy a cheap case and the screws round-out when installing a graphics card, its thin metal, it rattles, its a ngihtmare to cable manage if possible at all and lacks allot of features like usb3 ports or hard drive bays or cable management holes or space behind the motherboard for cables...
hard drive-gets filled within months and you find you have to buy another (this is assuming you file manage which you should do anyway)
