Office PC Build Help!
You might consider a mini-ITX build in a quiet case. Aside from the small footprint, most mini-ITX motherboards include WiFi and Bluetooth.
An i5 is likely more power than really needed, but coupled with 16GB of memory and an ssd it should make working with complex worksheets a breeze.
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor ($214.99 @ SuperBiiz)
Motherboard: ASRock H110M-ITX/ac Mini ITX LGA1151 Motherboard ($67.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory ($74.99 @ Newegg)
Storage: Crucial MX300 275GB 2.5" Solid State Drive ($69.95 @ SuperBiiz)
Case: Fractal Design Define Nano S Mini ITX Desktop Case ($49.99 @ Newegg)
Power Supply: SeaSonic 360W 80+ Gold Certified ATX Power Supply ($58.99 @ SuperBiiz)
Total: $536.90
Generated by PCPartPicker 2016-11-01 14:09 EDT-0400
