Hello there, one of my laptops shat it self to death and a friend of mine inspected it and he said that i had to get a new I/O board for it, but i could not find the model online, could i use any Laptop I/O board to fix the problem???
P.s
What should i know about I/O boards(Laptop)??
https://linustechtips.com/topic/683831-help-with-laptop-io/
P.s
It will be proprietary to the maker so no, an io from a similar model with the same connector is your best bet.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/683831-help-with-laptop-io/#findComment-8785675
Literally does not sound right. Ask a properly technician to inspect it. And you're fucked just saying. Because Razer solders EVERYTHING on the motherboard, you have to replace the entire motherboard, cpu, gpu and all. Experts may be able to de solder the bad components and resolder good ones on, but those guys are hard to find.
Laptop Main
(Retired) Zbook 15: i7-6820HQ, M2000M, 32gb, 512gb SSD + 2tb HDD, 4k Dreamcolor
(Retired) Alienware 15 R3: i7-6820HK, GTX1070, 16gb, 512 SSD + 1tb HDD, 1080p
(Retired) T560: i7-6600U, HD520, 16gb, 512gb SSD, 1620p
(Retired) P650RS: i7-6820HK, 1070, 16gb, 512gb + 1tb HDD, 4k Samsung PLS
(Retired) MBP 2012 Retina: i7-3820QM, GT650M, 16gb, 512gb SSD, 1800p
https://linustechtips.com/topic/683831-help-with-laptop-io/#findComment-8785760
1 minute ago, TheMightyDouche said:
It wont charge nor does the USB and HDMI work but the battery and everything else does. I am looking for this I/O board(shown in the picture)
OH you got lucky. You have 1 of the models where this was detachable.
Laptop Main
https://linustechtips.com/topic/683831-help-with-laptop-io/#findComment-8785767
16 minutes ago, TheMightyDouche said:
i found one on ebay but its $130 and my budget is $40
your budget is irrelevant at this point
its a $2k laptop, and and i would rather pay $130 to get it fixed than pay for a whole new laptop
also if you say the battery doesnt charge are you sure the battery isnt dead?
Photography / Finance / Gaming
https://linustechtips.com/topic/683831-help-with-laptop-io/#findComment-8785874
6 hours ago, TheMightyDouche said:
Lol i bought the laptop on ebay for $90 :D, anyway yea the battery works just not that i/o
Wow, what a steal and a presumably easy repair.
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
https://linustechtips.com/topic/683831-help-with-laptop-io/#findComment-8787675
