hyper 212, cryorig h7, there are more but those are a start.
CPU-i7 6700k O.C. 4.6Ghz-Motherboard-Asus z170-a-RAM-24gb DDR4-GPU-EVGA GTX 1080 FE-Case-Corsair 400c (white)-Storage-HDD: 2xWD Blue 1TB SSD: PNY SSDSC120GLC709B121-510 120GB-PSU-1000 watt coolermax-Display-ASUS VG248QE Black 24" 1080p 144 Hz -Cooling-Corsair H115i-Keyboard-G.Skill KM780 Cherry MX blues (Red backlight)-Mouse-Logitech G602-Sound-Logitech 5.1 z506
Need a budget headphone for under 100$? Sennheiser HD 558 Headphones
Got a Skylake CPU (k) Here is a guide to OC it!
https://linustechtips.com/topic/683798-top-cpu-fan-cooler/#findComment-8785338
Depends on the height of your ram. You need low profile sticks with that cooler. Or else get the dark rock 3. I've build a system with that one on an asus z170 and there was enough room for dual channel. The fan blocks the first slot though so for 4 sticks, you need to put the fan on the other side.
https://linustechtips.com/topic/683798-top-cpu-fan-cooler/#findComment-8785371
A H7 Cryochill is really nice for the money, you can dress one up with a Thermaltake Riing fan if you want some flashy LEDs.
https://linustechtips.com/topic/683798-top-cpu-fan-cooler/#findComment-8785373
