Hi guys, i'll build a new loop but i don't choose the fittings yet. Which are the best compression fittings for $8 or less? I need 10 3/8-5/8 compression fittings.
Another thing, i need too 90 degrees angle with rotatory, which do you recommend for the same price?
https://linustechtips.com/topic/68377-best-compression-fitting/
I like the Monsoon, but, i read that not close it good.
Moonsoon fittings have issues with Primochill and Tygon tubing
<p>Wires Suck :angry:
!fY0|_|(4|\|R34[)7#!5PMM37#3(0[)3:1337 70833|\|73R3[)!|\|49!\/34\|/4Y 4|\|[)93741!f3
https://linustechtips.com/topic/68377-best-compression-fitting/#findComment-936840
I'm using them with Primochill tubing. It works perfectly fine (so, no leaks or anything), but it
is a very tight fit and the tubing is very annoying to get onto the fittings, and the compression
nut is very tough to tighten down. I have also tested Clearflex at some point, and it was much
easier to get onto the Monsoon fittings.
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/68377-best-compression-fitting/#findComment-936856
That's what I meant by "has issues" it might vary but in my case they were almost impossible to get on.
https://linustechtips.com/topic/68377-best-compression-fitting/#findComment-936871
Ah OK, I wasn't sure if you might have meant leaks or something else. But yes, my experience
seems to be consistent with yours, rather annoying. When I do loop maintenance on ZEUS the
next time I will most likely replace the tubing with something else (possibly Norprene, I love how
it looks and really want to try it out, although I've heard it's a bit more prone to kinking that normal
PVC tubing).
EDIT:
Just remembered something: Primochill tubing has actually been a very tight fit with all of
the fittings I've used it on, at least the 16/10 mm variant. Just FYI.
https://linustechtips.com/topic/68377-best-compression-fitting/#findComment-936986
EDIT:
Works great with bittspower and swiftech fittings for me (I have 1 swiftech fitting because they ran out of bittspower ones :P)
https://linustechtips.com/topic/68377-best-compression-fitting/#findComment-937078
Huh, good to know, thanks! Alphacool fittings are on the "annoying list" IME.
And which is the best tubing in your opinion? In all aspects, flexibility, fittings compatibility, i mean, perfect seal with many compression fittings.
I have heard great things about Norprene, although it is certainly not for everyone.
But it is much more durable than normal tubing, some resellers even recommend it for
laying tubes in your house which stay there for years. I definitely plan on getting
some and trying it out for myself in the near future.
Alternatively I have heard good things about Primochill's Advanced LRT tubing (I
have the lesser sort of Primochill tubing, although apart from that tight fitting
issue it's worked well for me so far), but as mentioned you might run into tightness
issues with that as well with some fittings.
https://linustechtips.com/topic/68377-best-compression-fitting/#findComment-937170
Bitspower.
Accept no substitute.
Norprene is the best tube for stability,PVC tube normally used will fog or leech eventually,its the nature of the tube. PVC tube has a high porosity,water will permeate causing the fogging.
SR-2-2x X5650 Xeons-3x 670 FTW-1x 120Gb Force GT-1x 240Gb Force GT-1tb WD Green-12Gb Dom GT 1866-Platimax 1500w-2x HK3-2xD5-24v controller-3x RX 480's-3x NiBlk HK GPU blocks-Koolance tops-BP res-15x SP120's-Little Devil V8.
https://linustechtips.com/topic/68377-best-compression-fitting/#findComment-938503
Well....I have heard bad things about monsoon fittings not holding tube correctly and some finish issues but if you like them then get them.
https://linustechtips.com/topic/68377-best-compression-fitting/#findComment-938879
The finish on the ones I have was flawless, the only problem I've had with it is that
since the compression nut is very tough to tighten with the Primochill tubing, I slipped
and scratched the fitting with the tool they provide, but other than that they've been
OK for me.
As for the tube holding, that's not really an issue with how tight Primochill's tubing
fits onto the fittings, but it may be with other stuff, you'd have to try it out. Simply
looking at their construction, they do look less grippy than other fittings, but whether
or not that's actually an issue in practice I do not know. If you see to it that your
tube runs don't put too much stress on the connection with the fitting, you should
probably be fine though, but that may not always be as easy as it sounds.
https://linustechtips.com/topic/68377-best-compression-fitting/#findComment-938937
Swiftech makes great fittings for cheaper than Bitspower. I'm using a couple in correlation with Bitspower and I've never had a problem with them.
The only issue I've found with the fitting is trying to remove the compression when tubing is on them. You have to hold the tubing while unscrewing otherwise they tend to unscrew from the G1/4" end.
Bitspower on the other hand doesn't have that issue but they are a pain to unscrew in general because they get so tight.
https://linustechtips.com/topic/68377-best-compression-fitting/#findComment-942512
I use xspc ones as they are cheap and work well.
Sent from my MB865 using Tapatalk
FX8120 @ 5.0GHz | Sabertooth 990FX | Patriot Viper Xtreme 8GB @ 2133MHz | Powercolor HD7950 @ 1300/1800 | Bitfenix Shinobi XL Modded | Corsair AX850 | Mushkin 120GB & Seagate 2TB | Bitfenix Recon | 5X SP120 PE | 6X Yate Loon 120mm HS
Koolance 200 Res | 2X Koolance 360 Rads | Danger Den CPX Pro | EK 7950 Block | Koolance CPU Block | Bitspower & XSPC Fittings
Green Machine
https://linustechtips.com/topic/68377-best-compression-fitting/#findComment-942542
Just go with what you think looks the best for your build. I've got EK comps in one computer and Bitspower in another. Both do the same job in my opinion, It's all down to general looks I guess and budget of course. I have also heard bad things about the Monsoon fittings but I think they should be okay to use tbh.
Core - EVGA Classified 3 | i7 980x | 12GB Corsair Dominator GT | Lian Li P80 | Corsair 128 Neutron GTX | 2 x WD 500gb Velociraptor | Asus Xonar Xense | 2 x EVGA 590 | Enermax Platimax 1500
Water Cooling - Alphacool NexXxos 360 Monsta | TFC 360 | Alphacool D5 Vario | Alphacool 250 Tube res | EK Supreme HF Nickle Plexi | 2 x EK Nickle Plexi 590 WB | Aquaero 5 XT
https://linustechtips.com/topic/68377-best-compression-fitting/#findComment-943857
I think i'll go for the EK CSQ+EK-Tube ZMT. I want tygon but i'm mexican and is very difficult buy wc pieces, but now we have EK reseller.
What do you think? Or, i can try buy another fittings without tubing, one of my cousins will go to USA the next month but he return in plane.
Sent from my iPhone using Tapatalk - now Free
https://linustechtips.com/topic/68377-best-compression-fitting/#findComment-943888
EK fittings will be fine. However in regards to tubing see if you can get your hands on some Primochill advanced LRT. The tygon tubing looks great for a couple, clean crisp almost crystal like for a month before it realy gets cloudy.
https://linustechtips.com/topic/68377-best-compression-fitting/#findComment-944112
I'll use norprene, in case i use it PVC i go for the primochill :P
https://linustechtips.com/topic/68377-best-compression-fitting/#findComment-944128
