Youtube help
Go to solution Solved by zanthros,
Sometimes the stored data can become too much for the program to handle and it should be cleaned out from time to time. Glad I could help. Please use the "Solved" feature for your post so that others can benefit from the solution as well.
Make sure you are using the latest version and disable any plugins and try again.
                  Did I help you to fix your problem or at least did offer somewhat valuable advice? Consider giving my post a "informative" or "thumbs up".
SYSTEM 2: Modded G3 case with Gigabyte GA-G33M-S2L, Intel E8600 (O.C to 4.2GHz.), 4GB GSkill PC8500, Nvidia 8800GTS (512M), Cooling provided by Scythe Big Shrunkin, HDD 1 = OSX 10.9.5, HDD 2 = Windows 7 Pro X64. (Placed 3rd in MacMod  of the year 2012) (For info see:  http://insanelymac.com/forum/topic/285641-and-the-winner-for-macmod-of-2012-is/
LAPTOP: Inspiron 1720, Modded BIOS, X9000 Core 2 extreme OC'ed and undervolted to 3.4GHz (windows only) , 6GB DDR2 800, 8600M GT, 1920x1200 Glossy display, Sigmatel Audio, 2 Kingston HyperX 120GB drives (1 with Windows 7 x64 pro & 1 with OSX 10.9.5) X9000 Processor World Record Holder since 02/2013 on Geekbench 2 : http://browser.primatelabs.com/geekbench2/search?dir=desc&q=x9000&sort=score
https://linustechtips.com/topic/683476-youtube-help/#findComment-8782166
Try a different browser, such as Firefox.
Come Bloody Angel
Break off your chains
And look what I've found in the dirt.
Pale battered body
Seems she was struggling
Something is wrong with this world.
Fierce Bloody Angel
The blood is on your hands
Why did you come to this world?
Everybody turns to dust.
The blood is on your hands.
The blood is on your hands!
Pyo.
https://linustechtips.com/topic/683476-youtube-help/#findComment-8782184
Just now, Himommies said:
IT WORKS WITH EDGE but i wanna use chrome
Chrome is cancer now. Abandon ship, Google's the captain of it, let their stupid asses sink with it.
Come Bloody Angel
Pale battered body
Fierce Bloody Angel
Pyo.
https://linustechtips.com/topic/683476-youtube-help/#findComment-8782202
You get any kind of error message?
https://linustechtips.com/topic/683476-youtube-help/#findComment-8782210
Post your error messages. They will help in trouble shooting the problem.
https://linustechtips.com/topic/683476-youtube-help/#findComment-8782250
Have you gone into settings and deleted all history and cache? Try that first
https://linustechtips.com/topic/683476-youtube-help/#findComment-8782279
You may want to download CCleaner and run it as well.
https://linustechtips.com/topic/683476-youtube-help/#findComment-8782285
https://linustechtips.com/topic/683476-youtube-help/#findComment-8782441
