Hello guyz!
I just purchased the h45 cooler here are the reuslts
Ambient temperature=25-30C
Idle    =   29-30C
Working = 30-35
Gaming 42-50
Are these results ok? mean at this price these are the recommended results !
One more thing when i check my bios My pump which was inserted in cpu fan header on board was showing 4500 rpm and fan that was throwing air to radiator (the fan attached to cpu cooler radiator) was showing 1500 rpm while these settings i could hear sound like this ( trrrrrr like a hard drive tick sound)
How i overcome this solution?
I just put cpu cooler fan that is attached to radiator to my nzxt h440 casing fan chip that automatically control fans now its running at 400 rpm the fan and pump at 4200 and no noise Vola ! I checked system for 6 continuous hours and gaming too temp are above mentioned plz tell this is right solution i dont hear any sound now thanks!
https://linustechtips.com/topic/683273-corsair-h45-help/
20 minutes ago, LukaH said:
what cpu are we talking about? the temps are fine either way so no worry there and sounds like you solved your noise problem on your own good job. everything is ok is what you want to hear right? :)
Thank u bro its 6700k ( not overclocked yet) can i ask one more thing?
https://linustechtips.com/topic/683273-corsair-h45-help/#findComment-8780041
4 minutes ago, LukaH said:
you just did but you can ask another thing if you wish :)
Um after building new pc there are 5 fans in nzxt casing including radiator i though sound will not a problem meaning there is a bit noise when i sat next to pc what i am saying all 5 fans are producing together some sound coming out of system is it normal? when u put so much case in the pc does it happens ? you have to compromise lower noise?
https://linustechtips.com/topic/683273-corsair-h45-help/#findComment-8780234
If the system is too loud, identify where the noise is coming from.
You can use your hands to stop fans to see if they are the source.
https://linustechtips.com/topic/683273-corsair-h45-help/#findComment-8781528
well depending on the quality of the fans some will be louder than others pair that with a AIO pump and some noise is to be expected. if you want quiet fans people like to suggest noctua or be quiet fans.
GPU drivers giving you a hard time? Try this! (DDU)
https://linustechtips.com/topic/683273-corsair-h45-help/#findComment-8781924
