Super Flower Leadex Silver 550W or a Seasonic S12II 520W. :)
My Daily Driver:
Acer Predator Helios 300
»« Intel Core i5-8300H »« 16GB DDR4 RAM »« NVIDIA GeForce GTX 1060 6 GB »« Silicon Power A60 512 GB M.2 SSD »«
Toshiba PC L200 1 TB HDD »« Microsoft Windows 10 Home »«
While some more information would probably be helpful, i'd suggest the Seasonic S12II 520W, I have the 620W one and it's great
CPU: Intel Core i7 3820 @4.4GHz Motherboard: Intel DX79TO | Graphics Card: XFX RX 480 RS RAM:  16GB Corsair Vengeance LPX DDR3 @ 1600MHz Sound: Asus Xonar Essence STX | Storage: 1x Kingston UV400 120GB | 1x 3TB Seagate Barracuda | 1x WD Green 1TB | PSU: Seasonic S12II 620W | Case: NZXT S340 White | Cooling: NZXT Kraken x31
"cheapest" is the worst way to shop for power supplies.
give us these bits of information instead:
- what hardware are you powering with the power supply?
- your location mentions UK, do you have a preferred store?
- what is your budget? (no, "cheapest" is not a budget)
- how much would you mind your system catching fire?
Hmm, is this for your friend with the i5-6600k + Asus GTX 970 Strix?
If so, the cheapest, quality unit I would personally recommend for that system would be the Antec VPF450 (not VP450F - they're different) or the Corsair CX450M. I'm more leaning towards the Corsair.
