1 minute ago, ketchupvlekje said:
I was wondering which cpu cooler is suitable for overclocking and be relatively quiet, can you recommend me any? my budget is around €70,-
Hyper 212 EVO
Roses are red
My name is Roy
We caught the alligator that ate the De Luca boy
https://linustechtips.com/topic/682168-cpu-cooler/#findComment-8770287
Noctua: http://www.newegg.com/Product/Product.aspx?Item=N82E16835608041&cm_re=NH-U14S-_-35-608-041-_-Product
Be quiet!: https://www.amazon.com/Quiet-Dark-Rock-Cooler-LGA775/dp/B00HPX7IKU
Anything from Noctua and Be quiet are low noise high performance options, though the price is also high. If you want to go on a budget you can get a Hyper 212 EVO.
i5-6600k (4.6) | Dark Rock 3 | MSI GAMING X 1060 6GB | 8GB DDR4 | 120GB SSD & 1TB HDD | Crystal 460x
 | Acer GN246HL 1080p 24" 144hz & Acer G246HL 1080p 24" 60hz |
PSU Tier List | PC Partpickers: US Canada Australia UK
https://linustechtips.com/topic/682168-cpu-cooler/#findComment-8770327
Where are you shopping/located and what are you cooling?
https://linustechtips.com/topic/682168-cpu-cooler/#findComment-8770329
3 minutes ago, ketchupvlekje said:
The Netherlands, i5 3570k
Depending on how much you want to spend,
Kotetsu: https://www.alternate.nl/Scythe/Kotetsu-CPU-koeler/html/product/1113241?lk=9344
Fuma: https://www.alternate.nl/Scythe/Fuma-CPU-koeler/html/product/1236645?lk=9344
https://linustechtips.com/topic/682168-cpu-cooler/#findComment-8770353
1 minute ago, WoodenMarker said:
Thanks! :D
https://linustechtips.com/topic/682168-cpu-cooler/#findComment-8770367
