Blog Help
Go to solution Solved by ChaseB,
Just now, anybodykek said:
Yeah, you can, but no one really cares. ;p
Ok Thanks
Just now, Xanthe_2871 said:
Maybe. How bad is it?
Not that bad
5 minutes ago, ChaseB said:
Do blogs have rating like tv has "tv-14" or movies have like PG-13. Anyone have a link that I could look at to read.
As far as I know there are no standardized ratings for blogs beyond the "NSFW" tag which would be similar to "R" for movies.
Yes, it's 2871 as in the year 2871. I traveled all this way, back in time, just to help you. And you thought your mama lied when she said you were special-_-
https://linustechtips.com/topic/681921-blog-help/#findComment-8767606
As far as I know there is no standardized ratings for blogs beyond the "NSFW" tag which would be similar to "R" for movies.
Should I give a warning in like my terms. My blog has language and sexual jokes. No Pornographic Images.
Chase B
Sound Tech and GPU Expert
Are You New? Please Click on these links to help you out. Code Of Conduct | LTT Beginners Guide
https://linustechtips.com/topic/681921-blog-help/#findComment-8767614
https://linustechtips.com/topic/681921-blog-help/#findComment-8767631
Ok Thanks
Not that bad
Chase B
https://linustechtips.com/topic/681921-blog-help/#findComment-8767634
