I would really appreciate if u guys could review this build,
I know I'm overpaying for some things, but my budget is 2200 Euro's and I already own the 1080 Founders
http://de.pcpartpicker.com/list/rQjWr7
It's general purpose will be Gaming; and Photo, Video and 3D Editing as a Hobby (Pretty High-End)
No Peripherals needed atm.
750W for future proofing, once I'm going to SLI
Maybe a Custom Loop later on
Thx!
Edited by Ephy
Forgot some Things
https://linustechtips.com/topic/681605-first-build-review/
wow I am seriously green.......
good build but want do you want pc for?
case has plenty of hdd space , are you going to use them? that case is 58 cm tall like something from 2001 space odessy.
are you going to sli?
so basically im saying function determines form and you haven't described its function/useage or wether expandability is a criteria.
https://linustechtips.com/topic/681605-first-build-review/#findComment-8763811
True, let me edit the Thread real quick, I forgot xD
https://linustechtips.com/topic/681605-first-build-review/#findComment-8763815
750W is overkill, 500W is enough. You dont need such expensive ram, just get regular LPX. You could also get air instead of AIO if you really want to save, still performs well for much less.
Edit: Purpose of build? 6700K is faster for gaming, only buy 6800K if you need the extra cores.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/681605-first-build-review/#findComment-8763818
I dont really have to save, (have 2200 Euro's for everything and I own a 1080)
Thats why I'm willing to overpay for some things
I choose 750W if I ever want to SLI (which I will i the future) or add some Parts
And I know I forgot the purpose xD
https://linustechtips.com/topic/681605-first-build-review/#findComment-8763826
Your spending 2200 euro and you forget why? As I said, 6700K is faster for gaming. You will lose performance by going for the 6800K if you dont need it (Albeit not much but still).
PSU Tier List
My specs
PC:
Peripherals
https://linustechtips.com/topic/681605-first-build-review/#findComment-8763838
Guys he is building PC for gaming and video editing. Video editing will benefit a lot from those 2 extra cores with HT.
And he can overclock that CPU to 4,2GHz for daily usage. I know this CPU can handle higher OC, but 4,2GHz is OC that 99% of CPUs can handle with ease.
Everything look great, except RAM. I would get 4x8GB instead of 2x16GB.
It will look much better with 2 ram slots being used on each side.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/681605-first-build-review/#findComment-8763885
True, I don't think I will ever get 128GB RAM
https://linustechtips.com/topic/681605-first-build-review/#findComment-8763984
24 minutes ago, jools said:
+1 simon771
also for your own ref...
https://forums.overclockers.co.uk/showthread.php?t=18749453
yes you do need a large case
also personnel choice, maybe have
1tb sdd for OS and programs and a separate 3tb hdd for storage pics,psd's and video files etc...
Thats what I was thinking, but maybe 2TB will be enough for now, I can always buy more I guess
https://linustechtips.com/topic/681605-first-build-review/#findComment-8763986
I think Ill be ordering the parts at the end of this week, or next week, but no later I have been waiting since E3
https://linustechtips.com/topic/681605-first-build-review/#findComment-8763991
I would trade the 6800k for the 5820k, the only difference is .3ghz and like 12 pcie lanes and If you don't plan on sli it will be better, because its like half the cost. With the extra $300 you could get a 500gb Samsung 950 pro ssd. I would also consider adding more hard drive space. And getting a different case because you doing need on that big.
http://de.pcpartpicker.com/list/XvnNyf
Check out my gear here --> https://kit.com/JWMFilms
https://linustechtips.com/topic/681605-first-build-review/#findComment-8764002
Great mate!
I hope you will be happy with your new PC. I know I would be :P
Well iu 5820k is like 10% cheaper in my country, so not worth it for me.
But for OP ... not sure what is price difference in his country.
WD My Cloud 4TB
https://linustechtips.com/topic/681605-first-build-review/#findComment-8764024
1 minute ago, Simon771 said:
Great mate!
The difference is about 20$, thus Ill get the 6800K
I will get a 2 or 3 TB HDD, probz going Custom Loop later on and I really like the Case
https://linustechtips.com/topic/681605-first-build-review/#findComment-8764043
1 minute ago, jools said:
good luck with ya build , let us know with pics appreciated
ps. I have a 250gb ssd and a 2tb hdd and both half full, also video editing files can get large
Im going to start with a 1TB SSD, a 2TB HDD and add a few more later on, if necessary
https://linustechtips.com/topic/681605-first-build-review/#findComment-8764045
What would u bee paying for both Processors?
https://linustechtips.com/topic/681605-first-build-review/#findComment-8764059
Hard or soft tubing :D ?
WD My Cloud 4TB
https://linustechtips.com/topic/681605-first-build-review/#findComment-8764066
1 minute ago, Ephy said:
Nope, Im going with 2 of 16 I guess,
4 of 8 cost 350
2 of 16 cost 230
Nvm;
PCPartPicker is weird
2 x 16GB = 230$
4 x 8GB = 350$
2Kits of 2 x 8GB = 240$ (120$ each)
https://linustechtips.com/topic/681605-first-build-review/#findComment-8764324
