Case dont fit.
Go to solution Solved by aisle9,
3 minutes ago, Antony Leung said:
Hey @Runefox, @aisle9, i can close the side panel of the case, but the only problem is it push hard the 212 evo. is good idea let that push the evo? or not?
No. Anytime something really just doesn't want to close but you force it to anyway, you're exerting lots of pressure somewhere in that system. Given that the case you're using is on the cheap and flimsy side, that strain is probably borne by the side panel, which will eventually hopelessly warp and look like crap. If you're unlucky, that strain is being exerted by the side panel onto the 212, which is then transferring that stress to the motherboard and bending it.
Seriously, yank the 212, return it, get your $30 back and go with the stock cooler. It will not be loud, and it will not be mediocre. The G4400 is a cool-running chip.
Hello LTT Forums!
I recently upgrade my pc dad. he was using a 10+ year old computer.
Now i preparing to let him use this:
CPU: Intel Pentium G4400 3.3GHz Dual-Core Processor  ($58.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($24.88 @ OutletPC)
Thermal Compound: Gelid Solutions GC-Extreme 3.5g Thermal Paste  ($11.89 @ OutletPC)
Motherboard: ASRock H170M Pro4 Micro ATX LGA1151 Motherboard  ($61.98 @ Newegg)
Memory: Crucial Ballistix Sport LT 8GB (1 x 8GB) DDR4-2400 Memory  ($43.98 @ Newegg)
Storage: OCZ TRION 150 120GB 2.5" Solid State Drive  ($46.10 @ OutletPC)
Case: Zalman ZM-T1 PLUS MicroATX Mini Tower Case  ($25.50 @ Newegg)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($39.99 @ Newegg)
Wireless Network Adapter: TP-Link Archer T9E PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter  ($73.77 @ OutletPC)
Total: $387.08
Generated by PCPartPicker 2016-10-25 19:40 EDT-0400
Everything was good. asembly, installing windowns. install drivers and programs.
and the only problem is i cant close the other side case, because the 212 evo is too high.
What i do? Cut the copper part of the cooler or cut the side of the case?
Image here: http://imgur.com/a/lgL10
When i mean the copper part is this
ANY COMMENT, FEEDBACK IS APPRECIATED.
https://linustechtips.com/topic/680938-case-dont-fit/
Cutting the heatpipes would be a huge no-no for a variety of reasons.
I think the better question is why you're using a 212 EVO on a locked Pentium. If you've still got the stock cooler, put that on and return the 212. Problem solved.
I enjoy buying junk and sinking more money than it's worth into it to make it less junk.
https://linustechtips.com/topic/680938-case-dont-fit/#findComment-8756467
I want good temps. no the mediocre cooler from intel.
https://linustechtips.com/topic/680938-case-dont-fit/#findComment-8756476
Dude, it's a G4400. You could light it on fire and it wouldn't break 70C.
https://linustechtips.com/topic/680938-case-dont-fit/#findComment-8756485
You know, it might actually make a cool looking case mod if you could drill out holes on the side panel corresponding to the ends of the copper heat pipes. It'd be a little difficult to get the panel on and off though...An elongated groove would do it, but might not look as nice. Not that you're asking for anything but "how do I make this work"... I think it'd be much easier to drill the holes than it would be to cut the copper, not to mention the structural problems cutting the copper might introduce.
https://linustechtips.com/topic/680938-case-dont-fit/#findComment-8756486
Like spilling the fluid contained within the heat pipes all over the place, rendering them useless and the computer potentially ruined.
https://linustechtips.com/topic/680938-case-dont-fit/#findComment-8756503
That too. I stopped thinking for a moment there.
Yeah, I even had to double check on that one, but the 212 has fluid in there.
https://linustechtips.com/topic/680938-case-dont-fit/#findComment-8756552
https://linustechtips.com/topic/680938-case-dont-fit/#findComment-8756639
Just now, Bleedingyamato said:
There's fluid in heatsink pipes?
I'd thought they were just solid metal.
Not sure if they all have fluid, but the 212 definitely does.
https://linustechtips.com/topic/680938-case-dont-fit/#findComment-8756672
They're right i remember someone mention that.
Yeah, some have gases, some have fluids, I think others still are just metals. There's a surprising number of ways to do a heatpipe. Maybe an idea for an LTT episode someday...
https://linustechtips.com/topic/680938-case-dont-fit/#findComment-8756683
Interesting.  What purpose does the fluid have?
It's for convection, think a very small, self-contained water cooler. Helps to distribute heat across the whole surface area of the copper (and the fins attached to it).
https://linustechtips.com/topic/680938-case-dont-fit/#findComment-8756692
Heat transfer, just like the fluid in an AIO only there's no pump and a lot less room to travel.
https://linustechtips.com/topic/680938-case-dont-fit/#findComment-8756693
So having fluid in the heat pipes enhances heat transfer along them vs solid metal pipes?
https://linustechtips.com/topic/680938-case-dont-fit/#findComment-8756746
Yes, because the liquid is able to form convection currents due to the heating and subsequent cooling, while solid copper doesn't have that advantage. That allows the heat to be distributed more evenly across the whole surface area of the copper from the base to the top, and subsequently to the heatsnk's fins.
https://linustechtips.com/topic/680938-case-dont-fit/#findComment-8756764
