hello all ive got some problems with my new gtx 1070...
my pc specs
i5 6600k (ive removed the overclock for stability currently)
16gb gskill trident z
corsair cx 500
segate barracuda 1tb wd blue 2 tb and a 250 gb ssd
and im upgrading from a gtx 960 2gb (pny) to a asus gtx 1070 strix
but first i upgraded to a gtx 1070 founders but i had the same problem as i do currently so i refunded it and a few months later i bought a gtx 1070 strix and that didn't have any mouse stuttering but it was performing worse than my 960 in 3d mark (about a 8000 graphix score) and when its under stress it dropped off to about 13 fps on high in doom so i got a replacement and now my mouse is stuttering in the same way as the founders that i first bought and it is running at about 4 fps in 3d mark
ive tried to resolve it but uninstalling all of my drivers for my keyboard and mouse and the re installing them, and then using ddu (display driver uninstaller) to purge my system of display drivers and then i reinstalled them and the problem still persists but the really weirs thing is when my mouse stutters my keyboard led effects stutter at the same time
im sorta on my last legs here and i feel  like im doing something wrong so plz halp
https://linustechtips.com/topic/680632-gtx-1070-install-help/
my pc specs
corsair cx 500
Uninstall all of your drivers thag say "nvidea" that will include your physx driver, graphics driver, GeForce experience driver, and I think audio driver. Then go to the website GeForce and select the automatic version. Complete the driver install and it should fix you if you haven't done that already. I had the same problem with mine a while ago.
https://linustechtips.com/topic/680632-gtx-1070-install-help/#findComment-8753067
Did you remove the drivers from your old GPU?
PC Specs:
CPU: Intel i9 12900K
CPU Cooler: Corsair Hydro H150i Elite Capellix
Mother Board: MSI z690 carbon WiFi
RAM: Corsair DDR5 6400MT/S
Storage: 2TB Samsung 970 Plus NVMe, 240 SanDisk SSD Plus, Crucial MX300 750GB SSD
GPU: Nvidia RTX 3090Ti FE
Case: Phanteks NV5
PSU: Corsair RM1000X
OS: Windows 11 Home
Monitor: Acer Predator XB271HU 27" 1440p @ 165hz
Keyboard: Razer Black Widow Chroma
Mouse: Logitech G502
Sound: Sony MDR 1000x Headphones, Blue Snowball Microphone
Laptop Specs:
Gigabyte Aorus 15G
CPU: Intel i7 10875H
RAM: 16gb DDR4
Storage: 512gb NVMe, 1TB Crucial MX300 SATA SSD
GPU: Nvidia RTX 2070 Max-Q
https://linustechtips.com/topic/680632-gtx-1070-install-help/#findComment-8753076
corsair cx 500
well that might just be the reason
it's bad quality PSU and maybe after your upgrade, components need more power that this crapy PSU can provide.
The only thing left for you might be clean install of windows and see if that might help :) But it's higly unlikely.
Intel i7 12700K | Gigabyte Z690 Gaming X DDR4 | Pure Loop 240mm | G.Skill 3200MHz 32GB CL14 | CM V850 G2 | RTX 3070 Phoenix | Lian Li O11 Air mini
Samsung EVO 960 M.2 250GB | Samsung EVO 860 PRO 512GB | 4x Be Quiet! Silent Wings 140mm fans
WD My Cloud 4TB
https://linustechtips.com/topic/680632-gtx-1070-install-help/#findComment-8753078
Your psu probably can't handle the card. Also, try uninstalling the old gpu drivers.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/680632-gtx-1070-install-help/#findComment-8753132
13 minutes ago, Simon771 said:
corsair cx 500
but while running the benchmarks gpuz is saying that theres no drop gpu voltage
https://linustechtips.com/topic/680632-gtx-1070-install-help/#findComment-8753133
