USB Battery Pack care Question
Solved by Simon771,
If you are not planning to use it for more than few month, charge it to 50% and put it in the closet.
If you are using it regulary, just make sure that every few months you let it go down to 0% and recharge back to 100% to calibrate it.
Featured Topics
Bobzcpu ·
Posted in Power Supplies2 -
1
RZBAKA ·
Posted in New Builds and Planning4 -
1
Magnumenforce ·
Posted in Phones and Tablets2 -
1
Crash The Noise ·
Posted in Programs, Apps and Websites3 -
5
