Need a Replacement Phone
Go to solution Solved by Sydlexic Deity,
A Xiaomi Redmi Note 3/4 would do the trick.
As would most of their phones tbh
So my current phone, a Xperia M4 Aqua, has kicked the bucket. My contract has 1 year to go so I need a new phone for that time. I live in Canada so I think you'll know what our pricing is like right now. :( Any other ideas would be helpful but for now here's the specifications Budget is max $250 CAD but if I can get for less then $200 that would be amazing cause I'm saving for school.
I need:
LTE
Either 32GB storage or a micro-sd expansion
minimum 1GB ram
Android 5.1 or higher (or ios 9 or higher) - not that interested in apple but if a good deal is found i'll take it.
bluetooth 4.1
1280x720p screen
4.5' screen
Relatively ok camera if possible re. my M4 had a great camera but the sensor wasn't that amazing in certain light conditions but it was fine otherwise
Unlocked (I'm with Rogers but if the phone is good enough it'll last a while I'd like to be able to use it as a backup on what ever other carrier I go with once my contract is over.)
some sort of battery saver mode (I've been spoiled by Sonys Stamina Mode and Ultra stamina Mode which have saved my ass in many an occasion and are absolutely amazing)
What I would like (If possible on my budget) Not everything has to be met but as much as possible I would prefer))
16GB storage with a SD card slot
2-3 GB Ram
Android 6.0 with maybe support for 7.0
Full 1080p HD Screen or higher
5' Screen
NFC
FM Radio (am is not really needed but...)
Good camera
Temperature sensors in device
I looked at the LeEco Le S3 and the Le Pro3 but they are a little expensive for right now for me considering that $250 US is about 334 CAD.
The Asus Zenphone MAX looks ok but just ok
Any suggestions would be amazing because i'm kinda desperate right now considering that I use my phone for absolutely everything I do.
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
https://linustechtips.com/topic/680533-need-a-replacement-phone/
Note 4 on Ebay. New and unlocked.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/680533-need-a-replacement-phone/#findComment-8752174
1 minute ago, zMeul said:
That's the true Note 7.
I'm just glad the battery isn't Samsung. #Burn
https://linustechtips.com/topic/680533-need-a-replacement-phone/#findComment-8752182
2 minutes ago, zMeul said:
Thoughts on the MediaTek Helio P10 and the arm Mali T860 inside? Don't really know much about phone processors
RAINBOWS!!!
https://linustechtips.com/topic/680533-need-a-replacement-phone/#findComment-8752190
In the future it will be discovered that there was never anything wrong with the Note 7, it was instead an elaborate prank by several trolls. Samsung went on the sue the mastermind for $300 million and settled outside of court for an undisclosed amount.
Yes, it's 2871 as in the year 2871. I traveled all this way, back in time, just to help you. And you thought your mama lied when she said you were special-_-
https://linustechtips.com/topic/680533-need-a-replacement-phone/#findComment-8752211
I was looking for a budget phone as well while I wait for something interesting to come out.
Do you live close to the border?
Are you in a major city?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/680533-need-a-replacement-phone/#findComment-8752214
About an hour from the border but no passport right now. It ran out this year and I'm just too lazy to get it renewed cause It needs to change to an adult one and thats not cheap. Winnipeg. THE major city for my province.
RAINBOWS!!!
https://linustechtips.com/topic/680533-need-a-replacement-phone/#findComment-8752219
Ahh yeah. You could always sign up for the $100 rebate, buy the S3 and get it sent to one of the facilities that will reship it to Canada. It'd be a bit of work but likely well worth it. I intend to buy one just for shiggles.
https://linustechtips.com/topic/680533-need-a-replacement-phone/#findComment-8752224
Honestly, as I fellow Canadian, I know how you feel about hte pricing.
I'm currently using the Moto G2 from Motorola and I picked it up on Black Friday in 2014 at Staples for $200. I think you can pick it up now for $200 still as the original prie unlocked was $250 when I bought it.
Other than only having 1GB of RAM, and only 8GB of internal storage (though the issuse isn't as bad with Android 6.0 and it's feature to have external storage act as faster internal storage if you are willing to format you SD card.
It'll do you for the rest of your year of contract and if actually at the $200 mark and meets all of you minimum requirements.
My Moto G2 had a software issue where it would't boot, but I bought the $30 1 year extended replacement plan from Staples and they replaced it no questions asked so if any goes wrong, you have yourself a new phone for $30. And if you chose to get a different phone down the line or if they now longer carry the G2, you can use the value of the G2 ($200) on your next phone.
Other than the G2, Staples also carries the G3 for $300+ which isn't a significant upgrade from the G2, so I wouldn't reccommend it at that price. For the $350 range, the Asus Zenfone lineup is worth a look if you want a bigger 5.5" screen.
https://linustechtips.com/topic/680533-need-a-replacement-phone/#findComment-8752243
Xioami Redmi Note 4.
The 650 is a great chip and can toe to toe with the 808 and even 810.
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/680533-need-a-replacement-phone/#findComment-8752246
So I really really like the Redmi Note 4. :) I think I may have found my new phone!
So I can get it off Geekbuying.com (http://www.geekbuying.com/item/Xiaomi-Redmi-Note-4-Pro-Helio-X20-3GB-64GB-Smartphone---Gold-371578.html) for 253.45 CAD or off here http://nis-store.com/xiaomi-smartphones/xiaomi-redmi-note-4-high-edition-3gb64gb-dual-sim-gold/ which comes straight off Xiaomis site (http://xiaomi-mi.ca/redmi-note-4/xiaomi-redmi-note-4-high-edition-3gb64gb-dual-sim-gold/) for $286.99 CAD. Thoughts?
RAINBOWS!!!
https://linustechtips.com/topic/680533-need-a-replacement-phone/#findComment-8752301
Keep in mind you won't get full LTE coverage with the Redmi.
https://linustechtips.com/topic/680533-need-a-replacement-phone/#findComment-8753683
Thanks for letting me know. I completely forgot to check the bands supported. Just looked it up and i'm disappointed in the band support. Band 7 is the only one here supported. A major thing I loved about my M4 aqua was the massive Band Support. So it seems I won't be getting this one after all. Ah well the search continues :)
RAINBOWS!!!
https://linustechtips.com/topic/680533-need-a-replacement-phone/#findComment-8754768
Yeah. Band 7 is the "high speed" band, however it also has the worst penetration.
I'd seriously look into the S3 if you're looking for a budget device. $150 USD is hard to beat.
https://linustechtips.com/topic/680533-need-a-replacement-phone/#findComment-8754847
True it does look really good. The Umi Plus also looks nice for the bands supported but again price point is an issue. Unless anyone else has other better ideas I think I may hit the book and go for the Le S3. On the sale day of course :P
RAINBOWS!!!
https://linustechtips.com/topic/680533-need-a-replacement-phone/#findComment-8754971
You have to sign up for the rebate ahead of time, and it's technically only available in the US; so you'd have to use the mail redirection service.
The Umi looks nice, but unfortunately supports the same bands that the Redmi does. The P10 is a little old as well, and wasn't that strong to begin with.
There's no used or new in box phones locally? Should be able to get an older Moto X Pure, Z3, etc for that budget.
https://linustechtips.com/topic/680533-need-a-replacement-phone/#findComment-8755076
The rebate is automatically applied through Le Ecos store as a $100 credit on it. So technically it's useless unless you are planning to buy other things off the store. I've been looking locally but used everyone want exorbitant prices for older models and new is just well... jacked up or "new contract only for $0!"
RAINBOWS!!!
https://linustechtips.com/topic/680533-need-a-replacement-phone/#findComment-8757306
