What's your budget?
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/680139-need-help/#findComment-8747599
Budget and location/currency? Cant recommend much until we know more. PSU would be good too.
Please quote our replys so we get a notification and can reply easily. Never cheap out on a PSU, or I will come to watch the fireworks.
PSU Tier List
My specs
PC:
CPU: Intel Core i5-6600K @4.8GHz
CPU Cooler: Noctua NH-U14S
Motherboard:  ASUS Maximus VIII Hero
GPU: Zotac AMP Extreme 1070 @ 2114Mhz
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400
Storage: Samsung 850 EVO-Series 500GB
Storage: Western Digital Caviar Blue 1TB
Case: Cooler Master MasterCase Pro 5
Power Supply: EVGA 750W G2
Peripherals
Keyboard: Corsair K70 LUX Browns
Mouse: Logitech G502
Headphones: Kingston HyperX Cloud Revolver
Monitor: U2713M @ 75Hz
https://linustechtips.com/topic/680139-need-help/#findComment-8747618
12 minutes ago, Davidd said:
Nice setup but can you help me find a better graphic for my setup?
I can't help you until you tell us how much money you want to spend and what country you live in.
Like rn8686 said, your power supply info would help too
My rig:
https://linustechtips.com/topic/680139-need-help/#findComment-8747656
Well im from Macedonia the currency is Denar and i want to spend around 18000 denars=300euros
PSU? Depending on local prices, you could get a RX 480/470, maybe squeeze in a 6Gb 1060 (Don't buy 3Gb, bad value).
PSU Tier List
My specs
PC:
Peripherals
https://linustechtips.com/topic/680139-need-help/#findComment-8747718
Taking out that crappy gpu is a start, the igpu on the i3 is way better.
http://gpu.userbenchmark.com/Compare/Intel-HD-4000-Desktop-115-GHz-vs-Nvidia-GeForce-GT-610/2169vsm7736
22 minutes ago, Davidd said:
Here
Can you list an exact model psu?
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/680139-need-help/#findComment-8747836
