Hi, I'm building my first PC soon, and I wan't to know if these will work together. I know there is PC part picker but I've heard it can mess up,
CPU -
Intel i5 6500 - $205
Graphics card -
GeForce GTX 1060 - $200
RAM -
8 GB (4GB x2?)- $40
Case -
$30-$50
Motherboard -
Gigabyte LGA1151 Intel H170 Micro ATX DDR4 Motherboard (GA-H170M-D3H) - $90
PSU -
Rosewill 80 PLUS BRONZE Certified Power Supply ATX12V / EPS12V 550 Power Supply Hive-550 - $55
Memory -
1 TB HDD  (WD Caviar Blue)- $50
Toshiba OCZ Trion 150 120GB 2.5" 7mm SATA III Internal Solid State Drive TRN150-25SAT3-120G - $40
Also does anyone have a recommendation on what RAM and case I should get?
Thanks and have a nice day!
Ion (Main Build)        Overall Setup
i5 6500 3.2 GHz        -Blue snowball (White) thanks goodwill
MSI Mortar Arctic        -Logitech K120
Asus 1060 6GB Dual                                                             -Logitech Daedalus Prime G302
PNY CS1311 120 GB                                                            -Mousepad I made in 1st grade with my name on it
WD Caviar Blue 1 TB
Crucial Ballistix Sport LT White 16GB (8x2GB) 2400
NZXT S340 White
Corsair CXM 450W
Lenovo H320 (Old Pre-built PC)                                      Possible upgrade for H320
i5 650 3.2 GHz (heh)        Xeon X3470
Motherboard unknown                                                       Same Motherboard
iGPU        GT 1030 (MSI Low Profile Half Height)
Crucial 240GB SSD                                                           Crucial 240GB SSD
6GB DDR3 (4+2GB)                                                           8-10GB DDR3 (4+2+2GB/4+4+2GB)
Lenovo H320 case                                                             Lenovo H320 case
Unknown PSU (210W?)                                                     Same PSU (210W?)
https://linustechtips.com/topic/679968-is-building-a-pc-easy/
NOT AGAIN NOT AGAIN
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/679968-is-building-a-pc-easy/#findComment-8745695
What's your budget and what are you trying to do? play games, edit videos, stream? I'll help you throw something together.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/679968-is-building-a-pc-easy/#findComment-8745705
CPU -
Graphics card -
RAM -
8 GB (4GB x2?)- $40
Case -
$30-$50
Motherboard -
PSU -
Memory -
PLEASE use PCPartPicker. It may not detect every compatibility issue, but it's better than not using it. Also, most of your parts are ridiculously unspecific. Also, get a better PSU.
Skyggeis Specs:
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler
Motherboard: MSI Z170A SLI PLUS ATX LGA1151 Motherboard
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000
Storage: Samsung 850 EVO 250GB 2.5" Solid State Drive
Storage: Western Digital Caviar Blue 1TB 3.5" Hard Drive
Video Card: Zotac GeForce GTX 1070 8GB AMP! Extreme
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case Satin Black
PSU: Corsair RMx 750W 80+ Gold Certified Fully-Modular PSU
WiFi Card: Gigabyte GC-WB867D-I REV 4.2
Case Fan: Aerocool DS 140mm Black 93.4 CFM
Other: Coolermaster VGA Holder
Other: Phanteks LED Strip 1M
Other: Phanteks Fan Splitter
Monitor: Dell S2716DG
https://linustechtips.com/topic/679968-is-building-a-pc-easy/#findComment-8745717
wait wait guys ignore this please I'm new to the forums I accidentally copied the wrong thing, I've already got the components figured out.
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/679968-is-building-a-pc-easy/#findComment-8745718
2 minutes ago, Thread212 said:
Wow.. too good for a first timer.
8GB ram is enough.
Psu could be better u could buy either Evga g2 550w or antec edge 550w.
Though i prefer evga g2 myself.
the only reason i use antec edge is that i cant find evga psu around here.
first tell us your budget and i can recommend u some cases.
Memory is doesnt matter.
What do you mean by too good for a first timer? I'm actually building my PC next week, already ordered the parts (first time... but I've done WAYYYY too much research).
Skyggeis Specs:
https://linustechtips.com/topic/679968-is-building-a-pc-easy/#findComment-8745719
-SNIP-
yes its very easy. and all those parts will work well together. although i recommend a different ssd. spend a little more money getting a higher quality ssd.
NOT AGAIN NOT AGAIN
what?
CPU: I7 8700k @ 5ghz | Motherboard: Asus Z370-Prime | RAM: White Crucial balistix DDR4 2133mhz | GPU: GTX 1080TI | Storage: ssd HyperX 240gig, 2x2tb seagate Firecuda 1tb, BPX 480 gig nvme, 1tb sandisk ssd  | Cooling: Custom loop | PSU: Evga supernova 850w G2 | Case: Phanteks enthoo evolv atx black White modded | system theme: White/RGB/Weiss
https://linustechtips.com/topic/679968-is-building-a-pc-easy/#findComment-8745720
sorry sorry sorry this was on my clipboard from long ago please ignore this I already figured out everything
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/679968-is-building-a-pc-easy/#findComment-8745723
Guys please stop commenting I accidentally posted this.
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/679968-is-building-a-pc-easy/#findComment-8745725
Oh... okay...
Skyggeis Specs:
https://linustechtips.com/topic/679968-is-building-a-pc-easy/#findComment-8745729
Oh... okay...
Sorry if that came out as rude :P
WD Caviar Blue 1 TB
NZXT S340 White
Corsair CXM 450W
https://linustechtips.com/topic/679968-is-building-a-pc-easy/#findComment-8745733
Just now, Thread212 said:
Who the frag are u?
i was referring to QuantumBit.. O.o
I know. I'm just saying... don't say "good for a first-timer". I'm technically a "first-timer" but I know what I'm doing...
Skyggeis Specs:
https://linustechtips.com/topic/679968-is-building-a-pc-easy/#findComment-8745743
I built my first PC last August. It took me several hours because I got a really weird case with poor instructions: the Deepcool Steam Castle. It comes with four LEDs you have to plug into a circuit board, the circuit board plugs into the PSU using the SATA cable.
If it weren't for the weird case, I would have wasted less time because the motherboard (MSI Bazooka) made it super easy. Everything is labeled on the board and the instructions are super duper.
https://linustechtips.com/topic/679968-is-building-a-pc-easy/#findComment-8745807
