34 minutes ago, Harinder said:
hmm. So this is what it looked like when I reapplied the thermal paste the first time: http://imgur.com/gallery/KOxmf
(i put a bit too much) It seems like it made good contact, right?
Doesn't look like an even contact, see how the middle is thinner than the outside? I think your cooler block is warped (it could be the IHS but that's less likely). Seems like the block is warped and making a bad contact. Is it under warranty? You should RMA it.
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
4 hours ago, Harinder said:
Im pretty sure it was stepping, because at idle the clock speed dips down, but when I AIDA running, it goes up to 4gz.:S
No worries, it was just something to try. On second thoughts I dismissed the idea anyway, but still could have been useful to reset to defaults anyway for troubleshooting purposes, so I left my comment in. If trying to troubleshoot something it's the first thing to go, even if you KNOW it couldn't be the OC causing the problems IMO. Anyway, good luck with the problem, it's looking more and more like a defective AIO cooler then.
Ummm, is it just me... or does that look like the sticker is still on the block?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
1 minute ago, Harinder said:
No, thats just some residue from the pre-applied thermal past from the factory. I couldn't get it off-_-
Ahh I see, well it really needs to come off... the blocks/cpu should be really clean and free from any residue etc as that can greatly affect the thermal transference. Scrape it off with a soft plastic card or something as much as you can and then use iso-propyl (sp?) to get the rest off. It should come up nice and shiny.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
It looks ok. Not much in the centre though. Still would expect temps to be lower then what you are experiencing. Ate you using a fan controller?
Have you tried turning it off and on again?
No, but I think i have it figured out. I hooked up my sisters H100i and I got about 30-40c. And when im listening closely I can hear the pump. So im 80% sure the pump is broken on my H110i. Ill send it in for RMA.
It's not the thermal paste or how it was applied, @fixitnow. Here's why :
On 23/10/2016 at 9:00 AM, Harinder said:
when I feel the two pipes leading to the rad, one is cool, and the other is warm.
No amount of re-applying thermal paste is going to solve that (unless moving the tubes about accidentally de-clogs whatever is clogging up his cooler).
Only a few days ago, Jay explained to Jerry and the viewers how temperatures in waterloops work :
Starts at 1:34:00-ish, in case the timestamp doesn't work.
Jay's very clear about it : the difference in water temperature before and after a GPU waterblock is 2-3°C at most.  GPUs tend to generate a lot more heat than a CPU, so the difference on an AIO will be smaller.
A hot and a cold tube indicates that there's a serious problem with the flow of water, so either the pump has a problem or the radiator or tubes are clogged up.  Given that this is an AIO, the latter options seem unlikely.
With the info we've been given so far, my money's on the pump.
Ok. I am only 15 still learning. I agree. Its likely that the pump is dead or that the rad is clogged up. Of its not under warranty and you are getting a new on try undoing the tubing and see if more then just water comes out.  You might be able to re do the tubing. Have a look at how Linus takes apart his water cooler in on of the two last episodes of scrap yard wars series 4. If it's still under warranty then take it back and ask for a replacement or a refund.
On 10/23/2016 at 1:19 PM, fixitnow said:
Sorry, I meant what method you use to apply your thermal paste.
I suggest you do it like this:
6- Spread the Thermal paste out, you want a thin coverage all over the CPU. This is to ensure that all of the CPU die is in contact with the cooler. If you don't spread it out well enough the the thermal paste will act as an insulator rather then a heat transfer method. If you are doing this to a laptop then it dose not matter if TIM goes on the green part of the CPU.
This is completely unnecessary. No one suggests spreading out the thermal paste anymore as it literally does not help anything. Just put a pea sized spot down and then put the cooler on it.
As I said that's how I do it and I get the best results.
