I need some help with a modification to a speaker control puck thing. What I want to do is have two audio input play through my 2.1 speakers set up at the same time, but when I plug something into the AUX 2 jack it cut off the PC line in. So I was wondering if there was some mod I could do to the control puck that would allow me to play to audio sources at the same time? I'm thinking it's the jack its self that has some sort of bypass and that all I need to do is unsolder that pin and I should be good. Only problem is I don't know if it has one or where it would be, any ideas?
the bottom, the AUX jack is the bottom one, head phone is the top one
the top. AUX is the top jack
diagram of my setup
[NEW System] (CPU) i7-4790k (mobo) ASUS maximins V (GPU) AMD R9 380x (CPU cooling) Corsair h100 (PSU) EVGA 800w (Monitor's) LG 32" ultrawide @ 75hz and a Asus 27" IPS logitech g602 mouse
[OLD System] (CPU) amd athlon x4 760k@ 4.4ghz/ (mobo) MSI FM2-A55M-E33/ (GPU) Gigabyte windforce 7870 / (CPU cooling) Corsair h100/ (PSU) Corsair CX 430w/ (monitor) dell 1980x1080@60hz 21"/ a logitech keyboard and mouse. Phone: Samsung S5  Galaxy s10e .
OLD Laptop: Dell Latitude E6410 with i5 520m and Nvidia NVS 310
Laptop's: Dell precision m2800 i7 4610m with amd firepro w4170m
other laptop Asus.
https://linustechtips.com/topic/679483-pcb-audio-mod-help/
